enzymes
(Enzymes)
March 3, 2018, 11:37pm
1
I want to have Home Assistant display the number of minutes until the next bus arrives.
I have a sensor sensor.bus_estimated and its value is in UTC such as
2018-03-03T23:07:49Z
There’s two things I’d like to do
Convert that to local time, such as 9.49am
Calculate in how many minutes that is (eg., if the time is 9.45am, then it should calculate “4 minutes”)
The next parts to this will be if the bus is more than an hour away, then instead of displaying “in xxxx minutes” it would display the time.
Any help with formatting time is appreciated!
treno
(travis reno)
March 3, 2018, 11:59pm
2
Use a template to calculate the minutes until your sensor:
{{((as_timestamp(states.sensor.my_sensor.state)-as_timestamp(now()))/60) | int }}
Use a template to display the current time:
{{as_timestamp(states.sensor.my_sensor.state) | timestamp_custom("%X")}}
tom_l
March 4, 2018, 12:13am
3
{{ your_zulu_time_thingo | timestamp_local }}
woks to display in local time too.
treno
(travis reno)
March 4, 2018, 12:42am
4
To display hours and minutes:
{%set sec = as_timestamp(states.sensor.my_sensor.state)-as_timestamp(now())%}
{%set hr = (sec / 3600) | int%}
{%set min = sec / 60 - hr * 60%}
{% if hr > 0 %}
{{"%d:%02d" % (hr, min)}}
{%else%}
{{min | int}}
{%endif%}
enzymes
(Enzymes)
March 4, 2018, 1:02am
5
Thank you - so quick! I’ve been Googling and making a mess of this.
Treno your solution is perfect Thanks Tom as well
jirka
(Jirka Hronik)
August 3, 2018, 1:38pm
6
Just want to highlight that as_timestamp
works for converting string ISO 8601 time in UTC (ending with Z) into local time perfectly. This cannot be found in the docs, so thanks heaps!
LintHart
(Linton)
September 27, 2019, 7:08am
7
Apologies for hijacking the thread, I have a Template sensor to display the last time a snapshot was taking using the google drive plugin. This displays in UTC.
Really hoping there is an easy way to display in my local time in Australia. Also, hoping to customise the output, may it shorter like DD/MM HH:MM etc.
Current output is way too long:
2019-09-26T21:18:28.596753+00:00
Any tips appreciated
Linton
last_snapshot:
value_template: "{{ state_attr('sensor.snapshot_backup', 'last_snapshot') }}"
friendly_name: 'Last Snapshot'
