Forward persistent notifications to companion app
I want to forward persistent notifications to the iOS companion app. I created the following automation:
alias: forward persistent notification to companion app
description: ""
  - platform: state
    entity_id: sensor.persistent_notifications
condition: []
  - choose:
      - conditions:
          - condition: template
            value_template: |
              {{ trigger.from_state and trigger.to_state and
                 trigger.to_state.state | int > trigger.from_state.state | int }}
        sequence:
          - service: notify.mobile_app
            metadata: {}
              message: new message in Home Assistant
                push:
                  badge: "{{ trigger.to_state.state | int }}"
        alias: new message
      - conditions:
            value_template: |
                 trigger.to_state.state | int < trigger.from_state.state | int }}
        sequence:
            metadata: {}
              message: delete_alert
                push:
        alias: message removed
mode: single
Is there a way to get the title and message of the persistent notification so I can forward it to the iOS companion app?
Where are you getting sensor.persistent_notifications?
You have everything you need here if you use the right platform: Persistent Notification - Home Assistant.
sensor.persistent_notifications is provided by Spook.
Now I tried it with Persistent Notification as trigger. But this only works if I created a persistent notification by myself. When, for example, HASS reports Login attempt failed I don’t get a notification.
description: ""
  - platform: event
    event_type: call_service
    event_data:
      domain: persistent_notification
      service: create
condition: []
      title: "{{ trigger.event.data.service_data.title }}"
      message: "{{ trigger.event.data.service_data.message }}"
mode: single
Hi there,
I’m experiencing the exact same issue as described in the original post. I was wondering if you managed to find a solution or workaround for forwarding persistent notifications to the companion app. Any updates or insights would be greatly appreciated!
Thanks!
Unfortunately, I have not found a solution
I just stumbled upon this thread and wanted to share my implementation:
alias: Forward Persistent Notifications
mode: parallel
triggers:
  - trigger: persistent_notification
    update_type:
      - added
actions:
  - action: notify.mobile_app
      title: |
        {{ trigger.notification.title or '' }}
      message: |
        {{ trigger.notification.message }}
Documentation:
