3vasi0n
(Joseph Sanders)
February 9, 2018, 2:38am
166
Yeah I never installed the 3.0beta. I’m still on 2.0 for the meantime. I’m not seeing any files or a cache in the appdaemon though
Here’s what I have in the file…
dashboardsettings:
use_dashboard: True
create_dashboard: False
create_alarm_dashboard: True
dashboard_file_name: living_room_cam_dash
alarm_dashboard_file_name: living_room_cam_alarm_dash
screen_width: 1280
screen_height: 800
show_full_screen_dashboard: True
full_screen_alarm_switch: input_boolean.foscam_toon_alarm_dash
time_between_shows: 60
show_time: 30
the cash files are in
your_config_directory/compiled/css
your_config_directory/compiled/html
your_config_directory/compiled/js
i wanted to know what is in:
your_config_directory/dashboards/living_room_cam_alarm_dash.dash and
your_config_directory/dashboards/living_room_cam_dash.dash
3vasi0n
(Joseph Sanders)
February 9, 2018, 9:42am
168
I don’t see any compiled directories at all unfortunately. But here’s what’s in the alarm_dash.dash, the cam_dash uses the same url.
title: camera
widget_dimensions: [126, 131]
widget_size: [1,1]
widget_margins: [2, 2]
columns: 10
global_parameters:
use_comma: 1
precision: 0
use_hass_icon: 1
layout:
- my_camera(10x6)
my_camera:
widget_type: camera
entity_picture: http://192.168.1.9:8123/api/camera_proxy_stream/camera.livingroom?api_password=
title: livingroom
can you see the directory compiled?
hmm, without that dir, no dashboard can be shown, and you have dashboards, so you must have it somewhere.
whats all in your config directory?
3vasi0n
(Joseph Sanders)
February 9, 2018, 9:51am
172
the only directories inside of the appdaemon directory are apps, custom_widgets, and dashboards.
strange.
i must ask @aimc and @frenck if the compiled directory can be somewhere else.
3vasi0n
(Joseph Sanders)
February 9, 2018, 9:54am
174
I set up appdaemon using the appdaemon2 addon in hass.io , not sure if that makes any difference or not.
yeah it makes all the difference because with that i am trying to find things with my eyes closed
in a place where i never have been
ill have to wait for a reply from those guys, because i am out of options.
you could still try to edit your appdaemon.yaml
put this in it
hadashboard: # beneath this line
dash_compile_on_start: 1 #add this line
and restart you entire device.
aimc
(Andrew Cockburn)
February 9, 2018, 2:19pm
176
The compiled directory has to be in the same directory as apps - what that maps to in hass.io i’m not sure.
i thought so too.
so how can he find the dashboard dir, the appdeamon.yaml and show a pic from a dashboard, but not find the dir compiled???
3vasi0n
(Joseph Sanders)
February 10, 2018, 3:50am
178
this is all I can see in the appdaemon directory. I don’t think I can access it from ssh
aimc
(Andrew Cockburn)
February 10, 2018, 1:55pm
180
In 2.0 there is a bug where you need to create the compiled directory manually
but andrew how can he have a dashboard like he showed here:
Yeah the complete foscam dashboard has always worked fine other than being able to see the camera image and control the motion detection. I tried your suggestion but it didn’t change anything. This is what’s showing up [dashboard]
without a compiled dir???
aimc
(Andrew Cockburn)
February 10, 2018, 5:44pm
182
Sorry - didn’t see that, I have no idea.
3vasi0n
(Joseph Sanders)
February 11, 2018, 7:35am
183
I tried creating a compiled directory and it won’t let me for some reason. I also accessed the location with ssh and was able to see a compiled directory but it wouldn’t let me access it.
oke, so as i see it, the compiled dir is there, but its hidden by hassio.
that makes it hard to clear if there is something that is wrongly cashed there.
did you try the force compile setting?
3vasi0n
(Joseph Sanders)
February 13, 2018, 3:53am
185
Not that I’m aware of. How would I go about doing that?
