i did want to integrate older type foscam cameras also, but because i lost my testing person, i didnt want to wait any longer and released it only for newer type cameras.
2017-10-11 01:17:14.822061 INFO Loading Object foscam using class foscam from module foscam
2017-10-11 01:17:14.824500 WARNING foscam: Entity input_slider.foscam_brightness not found in Home Assistant
2017-10-11 01:17:14.825382 WARNING foscam: Entity input_slider.foscam_contrast not found in Home Assistant
2017-10-11 01:17:14.826165 WARNING foscam: Entity input_slider.foscam_hue not found in Home Assistant
2017-10-11 01:17:14.826938 WARNING foscam: Entity input_slider.foscam_saturation not found in Home Assistant
2017-10-11 01:17:14.827710 WARNING foscam: Entity input_slider.foscam_sharpness not found in Home Assistant
2017-10-11 01:18:05.647740 ERROR foscam: dashboard couldnt be written
2017-10-11 01:18:05.651474 ERROR foscam: alarm dashboard couldnt be written
2017-10-11 01:18:05.654810 INFO foscam: App started without errors
2017-10-11 01:18:05.655530 WARNING foscam: Entity sensor.foscam_last_error not found in Home Assistant
2017-10-11 01:18:05.744292 INFO App initialization complete
2017-10-11 01:18:05.745314 INFO Starting dashboard
2017-10-11 01:18:05.757444 INFO API is disabled
2017-10-11 01:18:05.829628 INFO Connected to Home Assistant 0.55.0
2017-10-11 01:18:12.425154 INFO New dashboard connected: IP Cams
2017-10-11 01:18:44.712723 INFO Dashboard disconnected
2017-10-11 01:19:18.461296 INFO function [get_dashboard] finished in 135 ms
2017-10-11 01:19:20.003359 INFO New dashboard connected: IP Cams
foscam:
class: foscam
module: foscam # the name of the py file you added to your apps
camsettings:
camera_type: F19828P V2 # give 1 of the known camera types
camera_name: yourcam # the name you gave it in home assistant
host: 192.168.1.201 # the ip address from your cam
port: '88' # the port from your cam (default is 88)
password: hass # password set for the cam (no strange symbols allowed)
user: hass # the username you use for the cam
logsettings:
loglevel: WARNING # setting this to INFO gets more info in the log
logsensorlevel: WARNING # the app creates a sensor with the last info. level can be changed
last_error_sensor: sensor.foscam_last_error # the sensor is created automaticly
picsettings: # these settings need to be created in home assistant (see below)
brightness_slider: input_slider.foscam_brightness
contrast_slider: input_slider.foscam_contrast
hue_slider: input_slider.foscam_hue
saturation_slider: input_slider.foscam_saturation
sharpness_slider: input_slider.foscam_sharpness
default_pic_settings_switch: input_boolean.foscam_default_picture_settings
flip_switch: input_boolean.foscam_flip
mirror_switch: input_boolean.foscam_mirror
auto_infrared_switch: input_boolean.foscam_auto_infrared
infrared_switch: input_boolean.foscam_infrared
ptzsettings: # these settings need to be created in home assistant (see below)
left_right_slider: input_slider.foscam_left_right
up_down_slider: input_slider.foscam_up_down
start_cruise_select: input_select.foscam_preset_cruise
stop_cruise_switch: input_boolean.foscam_stop_cruise
zoom_slider: input_slider.foscam_zoom
preset_points_select: input_select.foscam_preset_points
alarmsettings:
motion_sensor: sensor.foscam_motion # the sensor is created automaticly
motion_switch: input_boolean.foscam_motion_detect # also needs to be created in home assistant
soundalarm_sensor: sensor.foscam_sound_alarm # the sensor is created automaticly
sensor_update_time: '10' # the amount of time in seconds between checks from the cam
recordsettings:
snap_picture_switch: input_boolean.foscam_snap_picture_now # also needs to be created in home assistant
recording_sensor: sensor.foscam_recording # the sensor is created automaticly
save_snap_dir: /home/pi/foscam_snap/ # the dir where you want manual snapshots to be saved
dashboardsettings:
use_dashboard: True # if this is set to False no dashboards will be created or used
create_dashboard: True # creates a dashboard in your dashboard directory on initialize from the app
create_alarm_dashboard: True # creates an alarm dashboard
dashboard_file_name: foscam # the name that your dashboard gets
alarm_dashboard_file_name: foscam_fullscreen # the name that the alarm dashboard gets
screen_width: 1024 # the screenwidth you want to use for your dashboard
screen_height: 600 # the screenheight you want to use for your dashboard
show_full_screen_dashboard: True # if you dont want to use the alarm dashboard set it to False
full_screen_alarm_switch: input_boolean.foscam_toon_alarm_dash # a boolean to silence the alarmdashboard temperary
time_between_shows: 60 # minimum time in seconds between showing alarm dashboards
show_time: 30 # the amount of seconds the alarm keeps active
pi@chilipie-kiosk:~/conf/logs$ tail -f /home/pi/conf/logs/appdaemon_error.log
File "<frozen importlib._bootstrap_external>", line 661, in exec_module
File "<frozen importlib._bootstrap_external>", line 767, in get_code
File "<frozen importlib._bootstrap_external>", line 727, in source_to_code
File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
File "/home/pi/conf/apps/foscam.py", line 456
def create_alarm_dashboard(self):
IndentationError: unexpected unindent
