hadnt seen that, and i dont play around with settings that much
i changed it in the app.
you could copy the whole app or edit yours.
line 204 was:
data = urlopen(self.url + "set" + kwargs["settingstype"] + "&" + kwargs["settingstype"].lower() + "=" + new).read().decode()
and that is now:
if kwargs["settingstype"] == "Contrast":
data = urlopen(self.url + "setContrast&constrast=" + new).read().decode()
else:
@thundergreen
i expected that you knew that changes on HA yaml needs a restart from HA completely.
if you havent done that, then its no wonder that there are no input_sliders.
but i wanted to see the configuration.yaml from HA.
you need to have the input_slider set in there too, and i wanted to make sure you have it set there right.
do you see your other input_sliders? (from your alarm clock)
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 48.9771094
longitude: 2.8721844
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 79
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Paris
# customize
customize: !include customize.yaml
##### Web-Front_end Config##
config:
##### Android IP Cam ###
# android_ip_webcam:
# - host: 192.168.1.34
# - host: 192.168.1.17
# port: 8080
# Show links to resources in log and frontend
# introduction:
# Zeroconf
zeroconf:
# FFMPEG - AVCONV Fork for Raspbian
ffmpeg:
ffmpeg_bin: /usr/bin/avconv
# Cam
# camera:
# - platform: mjpeg
# name: Cam Phone Thorsten
# mjpeg_url: http://192.168.1.28:8082
# still_image_url: http://192.168.1.28/picture/2/current/
camera:
- platform: foscam
ip: 192.168.1.201
username: 'thundergreen'
password: '%%LogMeIn%%'
# - platform: rpi_camera
# - platform: mjpeg
# name: Cam Tablet
# mjpeg_url: http://192.168.1.28:8083
# still_image_url: http://192.168.1.28/picture/3/current/
# #image_rotation: 180
# image_quality: 80
# camera 2:
# - platform: generic
# name: Emilie
# still_image_url: https://maps.googleapis.com/maps/api/staticmap?center={{ states.device_tracker.pi_thorsten.attributes.latitude }},{{ states.device_tracker.pi_thorsten.attributes.longitude }},{{ states.device_tracker.pi_emilie.attributes.latitude }},{{ states.device_tracker.pi_emilie.attributes.longitude }}&zoom=13&size=500x500&maptype=roadmap&markers=color:blue%7Clabel:P%7C{{ states.device_tracker.pi_thorsten.attributes.latitude }},{{ states.device_tracker.pi_thorsten.attributes.longitude }},{{ states.device_tracker.pi_emilie.attributes.latitude }},{{ states.device_tracker.pi_emilie.attributes.longitude }}
# limit_refetch_to_url_change: true
############# INFLUX TEST #########
influxdb:
host: 192.168.1.234
# OpenALPR for registration plate recognition
# openalpr:
# engine: local
# region: eu
# confidence: 50.0
# alpr_binary: /usr/bin/alpr
# entities:
# - name: Camera Garage
# interval: 5
# render: image
# input: http://192.168.1.28/picture/1/current/
## Logger
logger:
default: error
# Switches
switch: !include switches.yaml
# Groups
group: !include groups.yaml
# Enables the frontend
frontend:
# Binary Sensors
binary_sensor: !include binary_sensors.yaml
http:
# Uncomment this to add a password (recommended!)
api_password: !secret http_password
trusted_networks:
- 127.0.0.1
- 192.168.1.22
- 192.168.1.48
- 192.168.1.28
# Uncomment this if you are using SSL or running in Docker etc
# base_url: https://emevth.no-ip.biz
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# Enable Recorder
recorder:
purge_days: 5
db_url: mysql://hass:[email protected]/homeassistant
# View all events in a logbook
logbook:
# Track the sun
sun:
# Automations
automation: !include_dir_merge_list automation/
# Scripts
script: !include scripts.yaml
#### SCENES #####
scene: !include scenes.yaml
# Weather Prediction
sensor: !include sensors.yaml
# Shell Commands
shell_command: !include shell_commands.yaml
# Input Boolean
input_boolean: !include input_boolean.yaml
# Text to speech
tts:
- platform: google
cache: true
cache_dir: /home/hass/.homeassistant/tts
time_memory: 300
- platform: picotts
language: 'de-DE'
# language: 'fr'
# Notify Services
notify: !include service_notify.yaml
# Device Tracker
device_tracker: !include device_tracker.yaml
# Input Select
input_select: !include input_select.yaml
# Image processing
# image_processing:
# - platform: openalpr_local
# region: eu
# source:
# - entity_id: camera.cam_garage
# Z-Wave AeonTech Gen 5
zwave:
device_config: !include zwave_device_config.yaml
usb_path: /dev/ttyACM0
config_path: /srv/hass/hass_venv/lib/python3.4/site-packages/libopenzwave-0.3.1-py3.4-linux-armv7l.egg/config
polling_interval: 60000
# # customize:
# lock.main_door_locked_2_0:
# polling_intensity: 1
### Custom Panels ###
##### Arduino Board
# arduino:
# port: /dev/ttyACM0
#panel_custom:
# - name: dmp
# sidebar_title: Digital Movie Poster
# sidebar_icon: mdi:movie
# config:
# kodi: 'media_player.kodi'
# api_pwd: xxxxxx'
### Panel I-Frame ###
panel_iframe:
router:
title: 'Router'
icon: 'mdi:router-wireless'
url: 'http://192.168.1.1'
ip_cam:
title: 'Security Cam'
icon: 'mdi:webcam'
url: 'http://192.168.1.28'
grafana:
title: 'Grafana Graphs'
icon: 'mdi:chart-areaspline'
url: 'http://192.168.1.234:3000'
backup:
title: 'Backup System'
icon: 'mdi:backup-restore'
url: 'http://192.168.1.234:55414'
# kodi_mediacenter:
# title: Media Center
# icon: 'mdi:kodi'
# url: 'http://192.168.1.40:8080/'
# ozwcp:
# title: Open Z-wave Control Panel
# icon: 'mdi:access-point'
# url: 'http://192.168.1.22:8090/'
# dashboard:
# title: Dashboard
# url: 'http://emevth.no-ip.biz:5050/MainPanel?skin=hygge'
# Mutlimedia
media_player:
- platform: kodi
host: 192.168.1.40
port: 8080
enable_websocket: false
turn_off_action: reboot
tcp_port: 9090
- platform: cast
- platform: lg_netcast
host: 192.168.1.27
access_token: 399887
# - platform: plex
# ip_address: 192.168.1.234
# entity_namespace: 'plex'
# include_non_clients: true
# scan_interval: 5
# show_all_controls: true
# use_custom_entity_ids: true
# use_episode_art: true
# MQTT Broker
mqtt:
discovery: true
discovery_prefix: homeassistant-MQTT
broker: localhost
port: 1883
client_id: home-assistant-1
keepalive: 60
username: pi
password: raspberry
# Alarm Control Panel
alarm_control_panel:
- platform: manual
code: 11122012
pending_time: 60
trigger_time: 120
disarm_after_trigger: true
# Light Platforms
# Philips Hue Platform
light:
- platform: hue
host: 192.168.1.38
allow_unreachable: true
#scan_interval: 10
# allow_hue_groups: true
# Hyperion Light
- platform: hyperion
host: 192.168.1.40
port: 19444
# Piglow
- platform: piglow
# Battery State
battery_state:
# Zones
zone:
- name: work_thorsten
latitude: 48.8768868
longitude: 2.3069316
radius: 250
icon: mdi:worker
- name: work_emilie
latitude: 48.9874818
longitude: 2.538180
radius: 250
icon: mdi:worker
- name: home
radius: 250
icon: mdi:home-map-marker
I will restart hass another time after creating the input sliders. Is my configuration.yaml ok ?
Anyway… my input_select won’t be shown in hass. Already restarted after adding those… I dont see whats wrong here
you dont have:
input_slider: !include input_slider.yaml
thats why your inputsliders wont show up
… wow… u r right … dunno how this could disappear in the config
I am restarting hass. will let u know
OK… I put in the input slider but error log wont show anything but:
pi@home-assistant:~/appdaemon_dashboard/appdaemon/conf $ tail -f /home/pi/appdaemon_dashboard/appdae
mon/logs/appdaemon_error.log
init_object(name, class_name, module_name, config[name])
File "/usr/local/lib/python3.4/dist-packages/appdaemon/appdaemon.py", line 592, in init_object
conf.objects[name]["object"].initialize()
File "/home/pi/appdaemon_dashboard/appdaemon/conf/apps/foscam.py", line 88, in initialize
self.run_every(self.get_sensors,runtime,repeat)
File "/usr/local/lib/python3.4/dist-packages/appdaemon/appapi.py", line 516, in run_every
raise ValueError("start cannot be in the past")
ValueError: start cannot be in the past
and
^Cpi@home-assistant:~/appdaemon_dashboard/appdaemon/conf $ tail -f /home/pi/appdaemon_dashboard/appdmon/logs/appdaemon.log
2017-05-09 15:46:47.101396 INFO foscam: devstate gaf foute data
2017-05-09 15:46:47.207275 INFO foscam: image setting gaf foute data
2017-05-09 15:46:57.115778 INFO foscam: devstate gaf foute data
2017-05-09 15:46:57.245078 INFO foscam: image setting gaf foute data
2017-05-09 15:47:07.093549 INFO foscam: devstate gaf foute data
2017-05-09 15:47:07.203678 INFO foscam: image setting gaf foute data
2017-05-09 15:47:17.113663 INFO foscam: devstate gaf foute data
2017-05-09 15:47:17.189825 INFO foscam: image setting gaf foute data
2017-05-09 15:47:27.089594 INFO foscam: devstate gaf foute data
2017-05-09 15:47:27.175971 INFO foscam: image setting gaf foute data
2017-05-09 15:47:37.116695 INFO foscam: devstate gaf foute data
2017-05-09 15:47:37.196277 INFO foscam: image setting gaf foute data
2017-05-09 15:47:47.145392 INFO foscam: devstate gaf foute data
2017-05-09 15:47:47.272666 INFO foscam: image setting gaf foute data
2017-05-09 15:47:57.129565 INFO foscam: devstate gaf foute data
2017-05-09 15:47:57.195847 INFO foscam: image setting gaf foute data
2017-05-09 15:48:07.073938 INFO foscam: devstate gaf foute data
2017-05-09 15:48:07.189146 INFO foscam: image setting gaf foute data
2017-05-09 15:48:17.130118 INFO foscam: devstate gaf foute data
2017-05-09 15:48:17.217689 INFO foscam: image setting gaf foute data
2017-05-09 15:48:27.118967 INFO foscam: devstate gaf foute data
2017-05-09 15:48:27.206675 INFO foscam: image setting gaf foute data
2017-05-09 15:48:37.114539 INFO foscam: devstate gaf foute data
2017-05-09 15:48:37.231454 INFO foscam: image setting gaf foute data
2017-05-09 15:48:47.329361 INFO foscam: devstate gaf foute data
2017-05-09 15:48:47.487533 INFO foscam: image setting gaf foute data
2017-05-09 15:48:57.079469 INFO foscam: devstate gaf foute data
2017-05-09 15:48:57.148668 INFO foscam: image setting gaf foute data
2017-05-09 15:49:07.145446 INFO foscam: devstate gaf foute data
2017-05-09 15:49:07.258408 INFO foscam: image setting gaf foute data
Do u know if special characters like % could harm ?
i think your device is a little to slow.
i didnt put in a delay for the run-in
in the app find the line:
runtime = datetime.datetime.now()
and make it:
runtime = datetime.datetime.now() + datetime.timedelta(seconds=5)
after that restart appdaemon.
that should get the error away.
and please show your appdaemon.cfg, because i think there must be another problem if you get that error every 10 seconds.
2017-05-09 16:27:13.409768 INFO AppDaemon Version 2.0.0beta3.5 starting
2017-05-09 16:27:19.651046 INFO Got initial state
2017-05-09 16:27:19.659801 INFO Loading Module: /home/pi/appdaemon_dashboard/appdaemon/conf/apps/foscam.py
2017-05-09 16:27:19.721232 INFO Loading Object foscam using class foscam from module foscam
2017-05-09 16:27:19.741905 INFO Loading Module: /home/pi/appdaemon_dashboard/appdaemon/conf/apps/hello.py
2017-05-09 16:27:19.749231 INFO Loading Object hello_world using class HelloWorld from module hello
2017-05-09 16:27:20.225108 INFO hello_world: Hello from AppDaemon
2017-05-09 16:27:20.235275 INFO hello_world: You are now ready to run Apps!
2017-05-09 16:27:20.237611 INFO App initialization complete
2017-05-09 16:27:20.240991 INFO Starting dashboard
2017-05-09 16:27:20.290330 INFO HADashboard Started
2017-05-09 16:27:20.292389 INFO Listening on ('192.168.1.22', 5050)
2017-05-09 16:27:20.318999 INFO Connected to Home Assistant 0.44.1
2017-05-09 16:27:24.130679 INFO foscam: devstate gaf foute data
2017-05-09 16:27:24.247420 INFO foscam: image setting gaf foute data
thats the config:
[foscam]
module = foscam
class = foscam
host = 192.168.1.201
port = 88
user = xxxx
password = xxxx
sensor_update_time = 10
motion_sensor = sensor.foscam_motion
recording_sensor = sensor.foscam_recording
soundalarm_sensor = sensor.foscam_sound_alarm
up_down_slider = input_slider.foscam_up_down
left_right_slider = input_slider.foscam_left_right
infrared_switch = input_boolean.foscam_infrared
auto_infrared_switch = input_boolean.foscam_auto_infrared
motion_switch = input_boolean.foscam_motion_detect
zoom_slider = input_slider.foscam_zoom
preset_points_select = input_select.foscam_preset_points
start_cruise_select = input_select.foscam_preset_cruise
stop_cruise_switch = input_boolean.foscam_stop_cruise
brightness_slider = input_slider.foscam_brightness
contrast_slider = input_slider.foscam_contrast
hue_slider = input_slider.foscam_hue
saturation_slider = input_slider.foscam_saturation
sharpness_slider = input_slider.foscam_sharpness
default_pic_settings_switch = input_boolean.foscam_default_picture_settings
mirror_switch = input_boolean.foscam_mirror
flip_switch = input_boolean.foscam_flip
snap_picture_switch = input_boolean.foscam_snap_picture_now
save_snap_dir = /home/hass/.homeassistant/foscam_snap/
oke, thats all correct.
i remember 1 thing.
did you install untangle, and in the same env as appdaemon?
pip3 install untangle
Yes I did. Appdaemon doesn’t run in venv so I installed untangle system wide with pip3 install untangle after I got the python error for missing untangle
do you still get the lines:
every 10 seconds?
if so could you edit foscam.py and blind out some lines for me?
in this function:
def get_sensors(self, kwargs):
#self.log(self.url + "getDevState")
#try: #<=THIS LINE
DevState = untangle.parse(self.url + "getDevState")
motion_alarm = DevState.CGI_Result.motionDetectAlarm.cdata # 0-Disabled, 1-No Alarm, 2-Detect Alarm
self.set_state(self.motion_sensor,state = motion_alarm)
if motion_alarm == "0":
self.turn_off(self.motion_switch)
else:
self.turn_on(self.motion_switch)
sound_alarm = DevState.CGI_Result.soundAlarm.cdata # 0-Disabled, 1-No Alarm, 2-Detect Alarm
self.set_state(self.soundalarm_sensor,state = sound_alarm)
recording = DevState.CGI_Result.record.cdata # 0-not recording, 1-recording
self.set_state(self.recording_sensor,state = recording)
infrared = DevState.CGI_Result.infraLedState.cdata # 0-Off, 1-On
if infrared == "0":
self.turn_off(self.infrared_switch)
else:
self.turn_on(self.infrared_switch)
#except: #<=THIS LINE
#self.log("devstate gaf foute data") #<=THIS LINE
#try: #<=THIS LINE
pic_settings = untangle.parse(self.url + "getImageSetting")
brightness = pic_settings.CGI_Result.brightness.cdata
contrast = pic_settings.CGI_Result.contrast.cdata
hue = pic_settings.CGI_Result.hue.cdata
saturation = pic_settings.CGI_Result.saturation.cdata
sharpness = pic_settings.CGI_Result.sharpness.cdata
self.call_service("input_slider/select_value", entity_id=(self.brightness_slider), value=brightness)
self.call_service("input_slider/select_value", entity_id=(self.contrast_slider), value=contrast)
self.call_service("input_slider/select_value", entity_id=(self.hue_slider), value=hue)
self.call_service("input_slider/select_value", entity_id=(self.saturation_slider), value=saturation)
self.call_service("input_slider/select_value", entity_id=(self.sharpness_slider), value=sharpness)
#self.log("image setting gaf foute data") #<=THIS LINE
edit the lines i marked with #<=THIS LINE
after you saved that, you dont need to restart AD
and please give me the log after 30 seconds or so.
i want to know what errors come up.
(and forgive me that i dont have a nicer debuging way, i am not a real programmer and this was only a first version )
Ok mate.will try that and let u know.thanks so far.awesome work indeed!;)
now it get:
2017-05-09 21:13:30.081359 WARNING ------------------------------------------------------------
2017-05-09 21:13:30.083744 WARNING Traceback (most recent call last):
File "/usr/local/lib/python3.4/dist-packages/appdaemon/appdaemon.py", line 514, in worker
function(ha.sanitize_timer_kwargs(args["kwargs"]))
File "/home/pi/appdaemon_dashboard/appdaemon/conf/apps/foscam.py", line 112, in get_sensors
File "/usr/local/lib/python3.4/dist-packages/untangle.py", line 66, in __getattr__
raise IndexError('Unknown key <%s>' % key)
IndexError: Unknown key <motionDetectAlarm>
2017-05-09 21:13:30.085071 WARNING ------------------------------------------------------------
2017-05-09 21:15:50.078744 WARNING Unexpected error in worker for App foscam:
2017-05-09 21:15:50.080639 WARNING Worker Ags: {'id': UUID('36fc7950-ce2c-47da-8a71-34fccb9ebfe9'), 'type': 'timer', 'function': <bound method foscam.get_sensors of <foscam.foscam object at 0x75bc5c70>>, 'name': 'foscam', 'kwargs': {'interval': 10}}
2017-05-09 21:15:50.082136 WARNING -
but if i see it right you only get the error once in a while.
you got it 21:13:30 and again on 21:15:50
so not every 10 seconds like before.
thats expected behaviour. i dont know what the cam sends, but at some moments the data isnt complete or deformed somehow.
at some periods i get the warning 5 times in 5 miutes then i dont get it for hours.
the warning is only there to show you how many times the sensors couldnt be updated.
in the version i am working on the second warning is going to zero, because i only collect the devicedata at the start of the app. after that only the sensors get pulled every 10 seconds.
if the warning is annoying you can replace the line:
with
return
after you did set things back to how they were
the problem is that the sliders and stuff wont work at all
the error appears all 5 seconds … i just badly copied and pasted here well… the functions in hass are zero… so no function for me
I think i know whats failing!!! it is indeed the % sign in my password!
