sorry i dont know what you mean.
i mean. If u select a present point⊠somtimes it happens that the cam goes to another position because of guard position or somewhat else. so it would be nice if the input_select would go back to a selct like âSELECTâ
Hey ⊠what would be the curl command to zoon in or out ? wanna make a script for dashboard
now i understand what you mean.
i will think about that one.
i dont know curl commands.
I actually implemented the controlls in DASBOARD my curl commands for controlling the foscam are:
# POSITION Garage
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=ptzGotoPresetPoint&name=Garage&usr=user&pwd=password"
# POSITION STREET
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=ptzGotoPresetPoint&name=Street&usr=user&pwd=password"
# POSITION Maindoor
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=ptzGotoPresetPoint&name=Maindoor&usr=user&pwd=password"
### Zoon In
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=zoomIn&usr=user&pwd=password"
## Zoon Out
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=zoomOut&usr=user&pwd=password"
##### Zoom Stop
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=zoomStop&usr=user&pwd=password"
### Move Left
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=user&pwd=password"
## move right
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=user&pwd=password"
#### stop moving
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=user&pwd=password"
### start Cruise
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=ptzStartCruise&mapName=House_complete&usr=user&pwd=password"
### stop cruise
curl -k "http://192.168.1.201:88/cgi-bin/CGIProxy.fcgi?cmd=ptzStopCruise&mapName=House_complete&usr=user&pwd=password"
Then I added scripts which have shellcommands
######## FOSCAM Positions ######
position_garage:
alias: Foscam present point garage
sequence:
- service: shell_command.garage
position_street:
sequence:
- service: shell_command.street
position_maindoor:
sequence:
- service: shell_command.maindoor
zoom_in:
alias: Foscam Zoom in
sequence:
- service: shell_command.zoom_in
- delay:
seconds: 2
- service: shell_command.zoom_stop
zoom_out:
alias: Foscam Zoom out
sequence:
- service: shell_command.zoom_out
- delay:
seconds: 2
turn_right:
alias: Foscam Turn turn right
sequence:
- service: shell_command.turn_right
- delay:
seconds: 4
- service: shell_command.stop_turn
turn_left:
alias: Foscam turn left
sequence:
- service: shell_command.turn_left
- delay:
seconds: 4
start_cruise:
alias: Foscam Start Cruising
sequence:
- service: shell_command.start_cruise
stop_cruise:
alias: Foscam Stop Cruising
sequence:
- service: shell_command.stop_cruise
please reedit your post and change your pasword.
you exposed it in the first lines.
i dont think we have to make scripts for al those things. but while i am lagging behind because off lots of other things at least you get what you want
Wow, this seems pretty cool ⊠Have anybody tried it with the Foscam R2? I donât have one yet, but it should be working from what I can gather?
That should be possible with ALL cgi able devices ⊠but u have to consult your manual what cgi commands u need.
here some âfinalâ pics
Everything will be mounted in a transparent box later with all i and stuff
Hi
Anyone know if this should work with FosCam FI9826P?
I did buy 2 of those, i get the controlls and everything in HA. I have configured Appdaemon (I think, correctly) but the when i use the controlls nothing happends.
I have 19828 and it works well. Just post all your related config files made anonymous and I will see if I see something which may be significant for malfunction
Please also post appdaemon log
I did send u a msg with all my config
I had to restart appdaemon before it worked⊠try this first
I have tried to restart appdaemon and HA like 3 times
I did try
http://192.168.1.6:88/cgi-bin/CGIProxy.fcgi?usr=admin&pwd=&cmd=getIPInfo
I get -2 as result that should be âbad passwordâ but i do type the correct password.
Any other command I should try?
I did try Zoom/Pan/Tilt via CGI and the Document i provided to me, works very well.
is there anything else then characters is your password?
when the firmware is up to date then that camera should work with those commands.
Yes i have 4 letters and 1 number in my password, is that a problem?
I did upgrade the fw on the camera, did restart HA + APPD + the Camera. Still nothing.
4 letters and 1 number shouldnt be a problem.
can you reach the camera with an app, or with firefox?
Yea i can use Firefox to control it, also the FosCam app.
I can also use the CGI commands in Firefox to zoom/tilt and so on.
Could it be something with the appdaemon and HA?
