Foscam E1 - Does it work with Hass?
I‘m searching for a wireless camera and find the Foscam E1:
https://www.foscam.com/E1.html
Does someone know if it is compatible to the Foscam component?
Did you ever give it a try? Or have experience with other battery powered cameras and Home Assistant?
I didnt try it:/ At work i played around with the blink system but that was pure shit and useless for hass because you can only pull the data from it and if you do it to often they will block you. I would be glad if someone can recommend a good wireless, battery solution.
