Was this ever fixed? I’m interested in doing automations in HASS based on motion form the Foscam.
I am also getting an error with the import (below). I followed the steps above that Rob did.
Any ideas how to get the import to work?
File "./foscam2mqtt.py", line 8, in <module>
from foscam import FoscamCamera
File "/usr/local/lib/python3.4/dist-packages/pyfoscam-1.2-py3.4.egg/foscam/__init__.py", line 1, in <module>
ImportError: cannot import name 'FoscamCamera'
I had to update the pyfoscam python library (/usr/local/lib/python3.4/dist-packages/pyfoscam-1.2-py3.4.egg/foscam/init.py) and this script to use the correct foscam.foscam namespace change:
OLD:
NEW:
from foscam.foscam import FoscamCamera
Thank you! Works great now.
Thanks for sharing the script.
i change in file follow your guide but get erro.
File “./foscam2mqtt.py”, line 7, in
from foscam.foscam import FoscamCamera, FOSCAM_SUCCESS
ImportError: No module named foscam.foscam
just a question… script works properly but how can i use it as i cannot see any values on motion detection i see that motion detection is 1 equal activated … but nothing more
ipcamera/Foscam {“infraLedState”: “1”, “soundAlarm”: “0”, “motionDetectAlarm”: “1”}
thats what i get… i never get payload 2. motion detection is well activated
FIXED! I just created a mqtt binary sensor… Will see if it works in a few minutes . Til now i use appdaemon for this but motion detection is very slow there and i guess will mqtt it is on the fly
Hello there,
I am new to running scripts with HASS. I currently have HASSIO and am looking to get a little more instruction. I have placed the foscam2mqtt.py file inside python_scripts folder inside of the configuration folder. Is this how I install it, or is there another way? Looking for some step by steps if possible. Thanks
I have a question as to the python script. How do you run it? Thanks in advance
So I have gotten the script placed and most working but I keep getting this error: Can anyone help?
File "/home/homeassistant/.homeassistant/foscam2mqtt.py", line 80, in <module>
main()
File "/home/homeassistant/.homeassistant/foscam2mqtt.py", line 61, in main
client.connect(args.mqtthost, args.mqttport, 60)
File "/home/pi/.local/lib/python3.5/site-packages/paho/mqtt/client.py", line 760, in connect
return self.reconnect()
File "/home/pi/.local/lib/python3.5/site-packages/paho/mqtt/client.py", line 887, in reconnect
sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
File "/usr/lib/python3.5/socket.py", line 712, in create_connection
raise err
File "/usr/lib/python3.5/socket.py", line 703, in create_connection
sock.connect(sa)
TimeoutError: [Errno 110] Connection timed out
how to add human detect sensor. Thanks
Good day, how do you continuesly run the script. I pressume it runs once reports the state and stops. How do you keep it active?
Thank you
