I am running several Foscam IP cameras (C1, R2) with home assistant and everything is fine.
Now I want to make at least one of the cameras to stream to the RP3’s HDMI port so that if I switch the TV to that HDMI input to see the camera stream. Is that possible?
No one? I think I need some player on the RPI that I will control with Home Assistant to run the IP camera stream to HDMI > TV.
Use case:
- someone at the door, bell-ringing, home assistant shows the stream on the TV.
- my kid’s room, etc. - so I can switch to HDMI3 port on the TV while I watch TV, etc.
I am running HA with AIO installer, Jessie, RP3.
I’ve done it with kodi. Topic closed
