FR. add offset to time condition
please consider adding the option of an offset to the time condition:
there is a WTH, but given the WTH season is now closed, let me ‘formally’ open this FR for that.
  - alias: "Example referencing a time helper"
    condition: time
    before: 23:00
    after: input_datetime.alarmclock_wd
    offset: -00:30
would be so helpful, making those time conditions be dynamic.
allowing an entity in the offset would even be better:
    condition: time
    before: 23:00
    offset: input_number.alarmclock_offset
use case
got a boiler I need to heat as close to the wakeup as possible, and the alarm clock changes frequently. can hard code only now
      - condition: time
        before: '23:00'
        after: '06:00'
but that is rather sub-optimal
There are two times so wouldn’t there be a need for two offsets?
before_offset
after_offset
Maybe it could be done per option:
    condition: time
    before: input_datetime.sleeptime
    offset: 00:15
    offset: -00:30
but if not, your solution would be best probably
I used the same offset naming scheme as in the Sun Trigger (edit: Sunrise/Sunset Condition).
really sorry but I dont understand what your are saying, those offset names are not documented at Automation Trigger - Home Assistant ?
Oops! My mistake.
I should have said Sunrise/Sunset Condition.
Yes! That is nice indeed, sorry I didn’t connect that myself.
How is this not a feature yet? It’s pretty confusing ux to have the time trigger and time condition work not both have an option for offsets. Hoping this gets added soon!
Yeah, I need this. Does anyone know an alternative way to have an offset to a date/time helper used as a condition?
