Free ALPR - Codeproject.AI
Since OpenALPR is not working for a long time(free). The new option for me is Codeproject.AI
  1. First of all install Codeproject.AI (If you install on windows don’t forget to open port 32168) and License Plate Reader addon
  2. Add to configuration.yaml
python_script:
  1. Connect with ssh to homeassistant and install python,requests for python, paho-mqtt for python
apk add python3
apk add py3-requests
apk add py3-paho-mqtt
  1. Do an automation to take snapshot from camera and run the shell command
  • service: camera.snapshot
    device_id: 478fb96ef90cc5d3dd6d0888db7f627c
    filename: /config/www/plate.jpg
  • service: shell_command.check_license_plate
    data: {}
  1. Code for /config/python_scripts/license_plate.py
import datetime
import requests
import random
import time
from paho.mqtt import client as mqtt_client
file = “/config/www/plate.jpg” #Your file - picture - to be checked
CODE_PROJECT_HOST = “http://192.168.x.xxx:32168#Your host
with open(file, ‘rb’) as fp: #request for Codeproject.AI
response = requests.post(
f’{CODE_PROJECT_HOST}/v1/image/alpr’,
files=dict(upload=fp),
plates = response.json() #respons from server
plate = None
plateM = “No plate”
#check if there is a plate
if len(plates[“predictions”]) > 0 and plates[“predictions”][0].get(“plate”):
plate = str(plates[“predictions”][0][“plate”]).replace(" ", “”)
score = plates[“predictions”][0][“confidence”]
#if there is a plate write the plate and the score of detection
with open(“/config/python_scripts/detected_plates.log”, “a”) as log:
log.write(f"[{datetime.datetime.now()}]: Camera - detected {plate} with a score of {score}\n")
plateM = str(plate)
#if there is no plate write a log that there was no plate
log.write(f"[{datetime.datetime.now()}]: - No plates detected in run\n")
#-mqtt broker
broker = ‘192.168.2.180’
port = 1883
topic = “python/mqtt”
#Generate a Client ID with the publish prefix.
client_id = f’publish-{random.randint(0, 1000)}’
username = ‘xxx’#insert mqtt username
password = ‘xxx’#insert mqtt password
#connection to mqtt broker
def connect_mqtt():
def on_connect(client, userdata, flags, rc):
if rc == 0:
print(“Connected to MQTT Broker!”)
else:
print(“Failed to connect, return code %d\n”, rc)
client = mqtt_client.Client(client_id)
client.username_pw_set(username, password)
client.on_connect = on_connect
client.connect(broker, port)
return client
#what to publish
def publish(client):
time.sleep(0)
msg = str(plateM)
result = client.publish(topic, msg)
# result: [0, 1]
status = result[0]
if status == 0:
print(f"Send {msg} to topic {topic}“)
else:
print(f"Failed to send message to topic {topic}”)
#run the process of publishing
def run():
client = connect_mqtt()
client.loop_start()
publish(client)
client.loop_stop()
run()
  1. Automation that will open the gate for known plates
alias: Tablice
description: “”
  • platform: mqtt
    topic: python/mqtt
    payload: 1234
  • platform: mqtt
    topic: python/mqtt
    payload: 2345
  • platform: mqtt
    topic: python/mqtt
    payload: 3456
  • platform: mqtt
    topic: python/mqtt
    payload: 4567
  • platform: mqtt
    topic: python/mqtt
    payload: 5678
    condition:
  • service: automation.trigger
    entity_id: automation.porton
    skip_condition: true
    mode: single
Happy new year
Hmm. Not working for me yet.
Folder python_scripts not found in configuration folder
It’s here “/homeassistant/config/python_scripts/license_plate.py”, so why doesnt it work? fixed.
Q2: By Payload 1234 you mean the license plate, right?
Q3: service: shell_command.check_license_plate, it cannot found that, are you not missing something?
Got the feeling this is incomplete :slight_smile: @Gregor_Tomazin
you installed Codeproject in HA?
try : \config\bashscript\license_plate.py
import datetime
import requests
import random
import time
file = "/config/www/plate.jpg"  # Your file - picture - to be checked
CODE_PROJECT_HOST = "http://192.168.1.XX:32168"  # Your Codeproject host
with open(file, 'rb') as fp:  # request for Codeproject.AI
        f'{CODE_PROJECT_HOST}/v1/image/alpr',
    plates = response.json()  # response from server
    plate = None
    plateM = "No plate"
    # check if there is a plate
    if len(plates["predictions"]) > 0 and plates["predictions"][0].get("plate"):
        plate = str(plates["predictions"][0]["plate"]).replace(" ", "")
        score = plates["predictions"][0]["confidence"]
        # if there is a plate write the plate and the score of detection
        with open("/config/python_scripts/detected_plates.log", "a") as log:
        plateM = str(plate)
    # if there is no plate write a log that there was no plate
    else:
    # -mqtt broker
    broker = '192.168.1.XX'
    port = 1883
    topic = "python/mqtt"
    # Generate a Client ID with the publish prefix.
    client_id = f'publish-{random.randint(0, 1000)}'
    username = 'XX'  # insert mqtt username
    password = 'XX'  # insert mqtt password
    # connection to mqtt broker
    def connect_mqtt():
            if rc == 0:
                print("Connected to MQTT Broker!")
            else:
                print("Failed to connect, return code %d\n", rc)
        return client
    # what to publish
        time.sleep(0)
        msg = str(plateM)
        # result: [0, 1]
        status = result[0]
        if status == 0:
            print(f"Send {msg} to topic {topic}")
        else:
            print(f"Failed to send message to topic {topic}")
    # run the process of publishing
    def run():
        client.loop_start()
        publish(client)
        client.loop_stop()
    run()
Go to : http://homeassistant.local:8123/developer-tools/action
1- Camera: Take snapshot
action: camera.snapshot
  entity_id: camera.street
2- Shell Command: check_license_plate
action: shell_command.check_license_plate
data: {}
automation : I’m still working on it.
Good luck :slight_smile:
Hi there
Thanks for the tutorial, got everythin installed (Snapshot from cam i stored correct and Codeproject.ai is on my Synology with Docker up an running) and configured exept the
data: {}
Here I got an error message from HA when I try to start manually…
Action shell_command.check_license_plate not found
whats wrong or could I do and how does HA has the link between
> * service: shell_command.check_license_plate
> data: {}
And the python-script?
this works
action: python_script.license_plate
data: {}
Got the shell running, now this message occurs:
Die Verarbeitung der zurückgegebenen Aktionsantwortdaten ist fehlgeschlagen. Es wurde ein Dictionary erwartet, aber es wurde <class ‘NoneType’> erhalten.
The processing of the returned action response data has failed. A dictionary was expected, but <class ‘NoneType’> was received.
whats wrong?? any idea?
thx Neo
