Free Cold Beer
Who doesn’t like Free Cold Beer? (total click bait)
Running a second fridge can take around 350kwh per year. This can be around $80 per year (depending on the cost of energy in your area).
Here is a simple ESPHome configuration for a Sonoff that will only turn the device on when your house is exporting energy to the grid (750w in this example).
Note that you will need a sensor inside HomeAssistant that knows the value of what you are Exporting/Importing.
## Beer Fridge
## filename: espbeerfridge.yaml
# Sonoff POW R2
# Button toggles power on/off
# Cron'd to check Solar every 15 minutes, on if there is Solar Exporting.
substitutions:
  upper_devicename: Beer Fridge
  devicename: espbeerfridge
esphome:
  platform: ESP8266
  board: esp8285
  arduino_version: 2.4.2
sun:
  latitude: !secret gps_latitude
  longitude: !secret gps_longitude
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_pass
# Enable logging
logger:
  baud_rate: 0
uart:
  rx_pin: RX
  baud_rate: 4800
# Enable Home Assistant API
api:
  password: !secret api_pass
ota:
  password: !secret ota_pass
status_led:
  pin: GPIO13
  - platform: uptime
  - platform: wifi_signal
    name: $upper_devicename WiFi Signal
    update_interval: 15s
  - platform: cse7766
    current:
    voltage:
    power:
  - platform: homeassistant
    name: "House Grid Power"
    entity_id: sensor.iotawatt_output_live_gridusage ###this is the sensor in Home Assistant that holds the value of your Solar Export
switch:
  ## restart
  - platform: restart
  ## relay / pump / compressor
  - platform: gpio
    pin: GPIO12
    name: $upper_devicename Compressor
    icon: mdi:glass-mug
binary_sensor:
  - platform: status
  ## button - toggle relay
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
    # Toggle pump when user presses the Sonoff Button
    on_press:
      - switch.toggle: compressor
## Use time
time:
    on_time:
      - seconds: 0
        minutes: /15  ###Note that Compressors should run for at leas 15min
        then:
          - if:
              condition:
                lambda: 'return id(gridpower).state > -750;'
              then:
                - logger.log: "Low or No solar export.  Less than 750w. Turn Off"
                - switch.turn_off: compressor
                - delay: 5s
              else:
                - logger.log: "Good solar export.  More than 750w. Turn On"
                - switch.turn_on: compressor
image image
Came here for the free beer and blueprints and got neither. :slight_smile:
You may want to remove the “Blueprints” tag from your post because it doesn’t appear to contain anything related to blueprints.
I believe this is a useful contribution to the Share Your Projects category.
Make it beerprints…
apologies, I haven’t been following HA as much… didn’t realise that ‘Blueprints’ were a new thing.
edited the original tags.
Probably worth mentioning that you should NOT use your fridge to store perishable items if you use this config!
Update demonstrating the fridge turning on this morning once power became available
