Free Google Assistant Integration without Port forwarding?
Is there currently any free Google Assistant Integration without Port forwarding/exposing or Home Assistant Cloud?
I mean just like the hue_emulation module did until it was deprecated.
Did u find a way to integrate? My ISP does not support port forwarding… :frowning:
If you want to remote access your Google Assistant or any device from outside of your home network without port forwarding setup, then try using SocketXP. SocketXP creates a secure remote tunnel to your home devices by-passing your home router or ISP. No router configuration or ISP configuration required.
SocketXP can be installed on any device - Raspberry Pi, Intel NUC, MacOS, Windows, Linux. SocketXP also has a dedicated add-on for Home Assistant Software.
Check it out here:
