Freebox integration error
I’m using the UI to add the freebox integration to my Home Assistant 0.108.5. I have a Freebox mini 4k
I followed the steps in the documentation, when setting the host/port and pressing the submit button I have an error “Unknown error: try again later”, and no arrow is displayed on the freebox
I have followed the initial setup to allow home assistant to have access to the freebox
and
I’ve tried rebooting the freebox and restart homeassistant but I still have this issue.
I’ve also tried to edit the configuration.yaml file to add the freebox data but it’s not working.
Do you have any clue ?
Hello
I had the same problem.
I was able to resolve this by checking
“activer l’authentification par mot de passe”
Sadly it is not stated in the doc.
This was the issue indeed !
Merci :slight_smile:
It has not solved my issue. Integration works well but I still have the warning log:
Logger: homeassistant.components.freebox.router
Source: components/freebox/router.py:194
Integration: Freebox (documentation, issues)
First occurred: 27 novembre 2023 à 18:43:29 (1 occurrences)
Last logged: 27 novembre 2023 à 18:43:29
Home access is not granted
Any clue why?
Same issue for me !
