Hi, I’m having an issue with the Freebox integration. It suddenly stopped working a few weeks ago due to this problem https://github.com/home-assistant/core/issues/133246, but even if it says resolved it’s not working anymore for me.
I tried deleting and resetting the integration using the right settings (from http://myiliadbox.iliad.it/api_version), but when i click Submit nothing happens on the router (it should appear something to give permission to HA to access it). I tried dozens of times but nothing, only a few times it gave me the error “already_in_progress”.
I don’t know what to do anymore
Hi, in the Freebox integration, fill the Host field with the value of api_domain that you get from http://myiliadbox.iliad.it/api_version and the Port field with https_port.
Hi Domenico, I’m going crazy with a new HA installation that refuse to connect to my IliadBox (freebox). I don’t have any integration configuration to change, just a SUBMIT button to press and I get a connection timeout: Cannot connect to host xxxxxxx.ibxos.it:49053 ssl:default [Connect call failed (‘192.168.1.254’,49053)]". Any suggestion? (we are both italian, so if it’s easier we can switch to italian)
Hi, I’m having exactly the same problem, did you manage to fix it in some way @gforment ?
(I’m also in Italy btw if you prefer to contact me, then we can write here the eventual solution for future reference)
Hi, I just installed an Iliadbox and got the same issue, did you find a way to solve it?
Take a look here: Freebox integration problem - #4 by BBE-FR
Yes, myiliadbox.iliad.it:443 are the info to be inserted
