Freeform weather station sculpture
Let me share my latest fun project. A freeform sculpture made with brass wires, D1 mini and some other components. It measures the humidity and temperature by two different sensors. It also has two indicator LED’s which show the battery percentage. The sculpture works on an 18650 battery which lasts for about two months.
I integrated the sculpture in Home Assistant by using Esphome with the following configuration:
esphome:
  name: freeform sculpture
  platform: ESP8266
  board: d1_mini
  on_boot:
    priority: 100.0
    then:
      - if:
          condition:
            lambda: 'return ((id(voltage).state /3.3) * 100.00) > 50;'
          then:
            - logger.log: "The sensor value is above 85%! Turn green leds on"
            - light.turn_on: green
            - delay: 2s
            - light.turn_off: green
      - if:
          condition:
            lambda: 'return ((id(voltage).state /3.3) * 100.00) < 50;'
          then:
            - logger.log: "The sensor value is beneath 60%! Turn blue leds on"
            - light.turn_on: blue
            - delay: 2s
            - light.turn_off: blue
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: light
  fast_connect: true
  ap:
    ssid: "Freeform"
    password: "xxxxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: !secret ota_password
ota:
# Enable Web server.
web_server:
  port: 80
deep_sleep:
  run_duration: 29min
  sleep_duration: 1min
i2c:
  sda: D2
  scl: D1
  scan: True
dallas:
  - pin: D5
binary_sensor:
  - platform: status
  - platform: adc
    pin: A0
    update_interval: 15s
    internal: true
    filters:
      - multiply: 3.3
    unit_of_measurement: 'V'
    icon: "mdi:battery-50"
    accuracy_decimals: 2
    lambda: |-
      return (id(voltage).state);
    unit_of_measurement: '%'
    lambda: |-
      return ((id(voltage).state /3.3) * 100.00);
    lambda: |-
    filters:
      - calibrate_linear:
          # Map 0.0 (from sensor) to 0.0 (true value)
          - 48.0 -> 0.0
          - 81.15 -> 100.0
  - platform: hdc1080
    temperature:
      name: "Freeform - HDC1080 Temperature"
    humidity:
      name: "Freeform - HDC1080 Humidity"
    update_interval: 20s
  - platform: dallas
    address: 0x00011939640DDB28
    name: "Freeform - DS18B20 temperature"
output:
  - platform: esp8266_pwm
    pin: D7
    pin: D8
light:
  - platform: monochromatic
    output: green_led
    default_transition_length: 3s
    output: blue_led
I will add an BMP280 later.
I hope this post will inspire someone else to make a freeform sculpture. If so, please post your result!
