Thanks for the quick response! ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
The response I get from running your script is below. Note that I have redacted my duckdns alias and API keys.
BlokmeisterNAS# python /mnt/Storage2/Other/Scripts/ha_host_monitor.py -c -v -s https://alias.duckdns.org:8123 API_KEY_REDACTED
Base URL: https://alias.duckdns.org:8123/api/services/mqtt/publish
SSL certificate check: False
blokmeisternas_8_8_8_8_state: {"last_boot": "2019-10-07T16:11:29", "cpu_load_1m": "0.57", "cpu_load_5m": "0.45", "cpu_load_1 5m": "0.40", "cpu_temperature": 34.0, "cpu_stat": {"user": 2.0, "nice": 0.0, "system": 3.3, "idle": 94.7, "irq": 0.0}, "memo ry_stat": {"total": 16804630528, "available": 5493555200, "percent": 67.3, "used": 10382729216, "free": 405114880, "active": 457871360, "inactive": 5088440320, "buffers": 0, "cached": 0, "shared": 240570368, "wired": 9924857856}, "swap_stat": {"tot al": 1572768, "used": 0, "free": 1572768, "percent": 0.0, "sin": 0, "sout": 5914}, "disks_stat": {"/": {"total": 11944650803 2, "used": 2804934656, "free": 116641573376, "percent": 2.3}, "/mnt/NewStorage": {"total": 27400687971840, "used": 193297414 28736, "free": 8070946543104, "percent": 70.5}, "/mnt/Storage2": {"total": 3140122140672, "used": 2482703224832, "free": 657 418915840, "percent": 79.1}, "/mnt/Storage2/Jails": {"total": 657419005952, "used": 90112, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage": {"total": 657423183872, "used": 4268032, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2 /iocage/download": {"total": 657419005952, "used": 90112, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/downl oad/11.2-RELEASE": {"total": 657704017920, "used": 285102080, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/i mages": {"total": 657419005952, "used": 90112, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/jails": {"total" : 657419005952, "used": 90112, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/jails/asigra": {"total": 6574191 77984, "used": 262144, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/jails/asigra/root": {"total": 6582881935 36, "used": 869277696, "free": 657418915840, "percent": 0.1}, "/mnt/Storage2/iocage/jails/transmission": {"total": 657419104 256, "used": 188416, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/jails/transmission/root": {"total": 658129 502208, "used": 710586368, "free": 657418915840, "percent": 0.1}, "/mnt/Storage2/iocage/log": {"total": 657419014144, "used" : 98304, "free": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/releases": {"total": 657419005952, "used": 90112, "fre e": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/releases/11.2-RELEASE": {"total": 657419005952, "used": 90112, "fre e": 657418915840, "percent": 0.0}, "/mnt/Storage2/iocage/releases/11.2-RELEASE/root": {"total": 658305945600, "used": 887029 760, "free": 657418915840, "percent": 0.1}, "/mnt/Storage2/iocage/templates": {"total": 657419005952, "used": 90112, "free": 657418915840, "percent": 0.0}, "/var/db/system": {"total": 8070947020800, "used": 477696, "free": 8070946543104, "percent": 0.0}, "/var/db/system/cores": {"total": 8070963302400, "used": 16759296, "free": 8070946543104, "percent": 0.0}, "/var/db/s ystem/samba4": {"total": 8070947341824, "used": 798720, "free": 8070946543104, "percent": 0.0}, "/var/db/system/syslog-3bc72 4bbb18d493585697320a07060e7": {"total": 8070946686976, "used": 143872, "free": 8070946543104, "percent": 0.0}, "/var/db/syst em/rrd-3bc724bbb18d493585697320a07060e7": {"total": 8070946686976, "used": 143872, "free": 8070946543104, "percent": 0.0}, " /var/db/system/configs-3bc724bbb18d493585697320a07060e7": {"total": 8071023985152, "used": 77442048, "free": 8070946543104, "percent": 0.0}, "/var/db/system/webui": {"total": 8070946686976, "used": 143872, "free": 8070946543104, "percent": 0.0}, "/ mnt/Storage2/iocage/jails/asigra/root/proc": {"total": 4096, "used": 4096, "free": 0, "percent": 100.0}}, "disks_temperature ": {"ada0": "31", "ada1": "31", "ada2": "30", "ada3": "30", "ada4": "30", "ada5": "30", "ada6": "32", "ada7": "31"}, "pools_ stat": {"NewStorage": {"total": 35734127902720, "used": 24513953800192, "free": 11220174102528, "percent": 68.6, "health": " ONLINE"}, "Storage2": {"total": 3985729650688, "used": 2978206695424, "free": 1007522955264, "percent": 74.7, "health": "ONL INE"}}, "alerts": "[WARNING] New feature flags are available for volume NewStorage. Refer to the \"Upgrading a ZFS Pool\" su bsection in the User Guide \"Installing and Upgrading\" chapter and \"Upgrading\" section for more instructions.\n[WARNING] New feature flags are available for volume Storage2. Refer to the \"Upgrading a ZFS Pool\" subsection in the User Guide \"In stalling and Upgrading\" chapter and \"Upgrading\" section for more instructions.\n[CRITICAL] Pool jailusb state is UNKNOWN: "}
