No, I am running HA on a raspberry pi 4. The values are pulled over the local network using FreeNAS’s API.
If you had HA in a jail, you still wouldn’t be able to pull values locally. The jail prevents you from reading data from your main FreeNAS. If you installed HA in your main FreeNAS install area, that might be possible, but it is not recommended to touch your main FreeNAS install base.
I see there are a few different ways to pull information from our NAS
- Using the API
- Commands over
ssh - Using @Limych Solution
- Using SNMP Monitoring
I just started making some sensors to test using the 2.0 API on TrueNAS
It appears all the information I could want is available using the new API, however, considering there are other methods to retrieve this data, I’m wondering – Is using the API the best (or preferred) way to go??
I don’t want to spend a bunch a time making rest sensors only to find out later, I should have done something else
– Thanks
I’d prefer to use the API to poll information from FreeNAS instead of pushing it to HA.
A push method will prevent HA from attempting to pull if FreeNAS is down, but I think it is a matter of can you get all of the data that you want with your chosen method and which method are you most comfortable with.
Does anyone else have more experience with getting sensor information of FreeNas via REST APi 2.0?
I built few sensors with 1.0 and I´m not fully satisfied with, so I´m considering to realize that with 2.0.
But honestly I don´t know how to start. Even I don´t know how to see information via webbrower directly on the NAS: I am use to open
http://IP -OF-YOUR-FREENAS/api/v1.0/storage/volume/VOLUME-NAME/?format=json but with 2.0 it doesn´t work.
@troy: Maybe you could push me in the right direction.
From the beginning, here’s what I got so far – for example first get a list of the reporting graphs, then second two commands are each ways of pulling the cputemp data, the start and end times are an epoch timestamp.
curl -X GET "http://localhost/api/v2.0/reporting/graphs" -H "accept: */*" --user 'root:password' | jq
curl -X POST "http://localhost/api/v2.0/reporting/get_data" -H "accept: */*" -H "Content-Type: application/json" -d '{"graphs":[{"name":"cputemp"}],"reporting_query":{"start":"1596338230","end":"1596338231","aggregate":true}}' --user 'root:password'
curl -X POST "http://localhost/api/v2.0/reporting/get_data" -H "accept: */*" -H "Content-Type: application/json" -d '{"graphs":[{"name":"cputemp"}],"reporting_query":{"unit":"HOUR","page":0,"aggregate":true}}' --user 'root:password'
Here’s how far I got making a package file using the – REST sensor
## FreeNAS / TrueNAS Core example sensors - RESTful API ver 2.0
homeassistant:
customize:
sensor.nas_info:
icon: mdi:server-network
hidden: true
## system information
- platform: rest
resource: http://10.10.1.10/api/v2.0/system/info
headers:
Authorization: !secret tn_bearer_token
User-Agent: Home Assistant
scan_interval: 3600
value_template: '{{ value_json.uptime }}'
json_attributes:
- uptime
- version
- model
- cores
## template sensors can extract state_attr
sensors:
## NAS Uptime
nas_uptime:
friendly_name: "Uptime"
value_template: "{{ state_attr('sensor.nas_info', 'uptime') }}"
entity_id: sensor.nas_info
## NAS Version
nas_version:
friendly_name: "Version"
value_template: "{{ state_attr('sensor.nas_info', 'version') }}"
## CPU model
nas_cpu_model:
friendly_name: "Model"
value_template: "{{ state_attr('sensor.nas_info', 'model') }}"
## CPU num of cores
nas_cpu_cores:
friendly_name: "Cores"
value_template: "{{ state_attr('sensor.nas_info', 'cores') }}"
## check status of mosquitto plugin
- platform: rest
resource: http://10.10.1.10/api/v2.0/plugin/id/mosquitto
headers:
scan_interval: 3600
json_attributes:
- name
- state
value_template: '{{ value_json.state }}'
## cpu temp version 2
## remember - set `cores=$num` in the value_template
- platform: rest
resource: http://10.10.1.10/api/v2.0/reporting/get_data
headers:
device_class: temperature
unit_of_measurement: '°C'
scan_interval: 60
method: POST
payload: >-
"graphs":[{"name":"cpu"},{"name":"cputemp"}],
json_attributes_path: "$.[0]"
json_attributes:
- aggregations
value_template: >-
{% set tn = namespace(temp=0, cores=8) %}
{% for core in range(0, tn.cores) %}
{% set tn.temp = tn.temp + value_json[1].data[358][core] %}
{% endfor %}
{{ "%.1f"% (tn.temp / tn.cores) }}
## Pools
- platform: rest
resource: http://10.10.1.10/api/v2.0/pool/id/19
headers:
scan_interval: 3600
json_attributes:
- name
- scan
- topology
- is_decrypted
value_template: '{{ value_json.status }}'
It was about this point I started to realize with the amount of api calls and data parsing required, using the REST sensor alone was gonna be a bit of work. For this, and also weighed heavily by other off-topic ( ideas for the TrueNAS plugin and needing to replace G-Music Player integration with Y-Tube Music ) reasons, I decided to just go for the custom integration even though it’s likely to be a complete uphill battle
It’s pretty rough at this point but I think with a little more time, I’ll at least have a basic sensor that pulls in some parsed data from the api, making it easier to break out with template sensors. I have a lot of ideas but I’m trying to stay focused on some basic ground work for now.
well, this is great. Actually I mostly do understand what you´re doing there
But I´ve got one big issue: WIth
json_attributes:
- uptime
- version
- model
- cores
you´re getting the needed values, but how can I see what possible values also available? in API 1.0. I was able to see all information with one (unformated) website. Then I simply used each parameter needed. In 2.0 I´m not able to get any information. On http://freenasip/api/docs/ or http://freenasip/api/v2.0/ I always get 401 unauthorized message. I typed your curl commands with my user, that worked
I never used the 1.0 API so I’m unable to relate the differences.
Same here, I didn’t much time trouble-shooting though, I figure it’s missing login credentials but I don’t see a way to edit / add those from the web page view.
I’m just taking the primitive approach. I have the api page open for reference, and I’ve just been working my way through bit by bit using curl and piping through jq to help make results easier read in the terminal.
json_attributes:
- uptime
- version
- model
- cores
These attr came from system/info
curl -X GET "http://localhost/api/v2.0/system/info" -H "accept: */*" --user 'root:password' | jq
"version": "TrueNAS-12.0-BETA",
"buildtime": [
"$date": 1593538042000
"hostname": "truenas.local",
"physmem": 34081218560,
"model": "Intel(R) Xeon(R) CPU E3-1245 v5 @ 3.50GHz",
"cores": 8,
"loadavg": [
0.154296875,
0.21337890625,
0.21728515625
"uptime": "10:02AM up 12 days, 18 hrs",
"uptime_seconds": 1101606.12825346,
"system_serial": "0123456789",
"system_product": "Super Server",
"system_product_version": "0123456789",
"license": null,
"boottime": {
"$date": 1596297744000
"datetime": {
"$date": 1597413750128
"birthday": {
"$date": 1593886329149
"timezone": "America/New_York",
"system_manufacturer": "Supermicro",
"ecc_memory": true
Sorry for my late answer. I didn’t have time to take care of things over the weekend.
Too bad, with the web interface it was very convenient. OK, thanks to your tip on the command line, I’m able to use the API documentation to get the relevant information. It’s a bit of work in the beginning, but the main thing is that it works. I could only go via the API key because I can’t create an API key. I think this is because I’m still on FreeNas 11.3.4 and I can’t create an API Key.
Thanks for your support!
@troy, have you had a chance to play around more with the 2.0 API? Anyone else?
I can’t find a simple way to pull the available space in a pool, ideally just as a percentage free or something like that. The old sensor had a used_pct attribute.
Also, I don’t know how to properly handle the alerts. Right now I’m using:
- platform: rest
resource: http://192.168.1.4/api/v2.0/alert/list
headers:
Authorization: !secret tn_api_key
scan_interval: 300
json_attributes:
- level
- formatted
value_template: >
{% if value_json is defined %}
{{ value_json[0].level }}
{% else %}
{{ "None" }}
{% endif %}
sensors:
## Alert message
tn_alert_message:
friendly_name: "Alert Message"
value_template: "{{ state_attr('sensor.tn_alert_level', 'formatted') }}"
But I get errors if there are no alerts despite the conditional.
Hi @reven
Sorry, not yet. I have not been very motivated on the computer these last few weeks
. I hope to be back at it soon though.
This is what I have to get used allocation in a pool.
- platform: rest
resource: http://192.168.1.180/api/v2.0/pool/id/1
headers:
Authorization: mytoken
value_template: '{{ value_json["status"] }}'
json_attributes_path: '$.topology.data[0].stats'
json_attributes:
- allocated
- size
scan_interval: 1800
sensors:
nas_storage_usage:
friendly_name: "Nas Storage Usage"
value_template: ' {{ (state_attr("sensor.nas_st\
orage", "allocated") / state_attr("sensor.nas_storage",\
"size") * 100) | round(1) }} '
unit_of_measurement: "%"
Thanks @MatthewFlamm!
So with all the bits and pieces that everyone has posted here and elsewhere, these are my TrueNAS sensors that all work with the 2.0 API and don’t rely on scripts, and this is my monitor page:
Hope it’s useful to someone and feel free to suggest improvements.
# TrueNAS sensors
# All of the sensors have been ported to use the v2.0 API.
# Current sensors:
# rest:
# tn_info (uptime, version, model, cores)
# tn_cpu_temp
# tn_alert_level *
# tn_pool
# tn_disk_temp
# template:
# tn_uptime_seconds
# tn_uptime
# tn_pool_pct_used
# tn_version
# tn_cpu_model
# tn_cpu_cores
# tn_alert_message
# tn_ada0_temperature
# tn_ada1_temperature
# tn_ada2_temperature
# General info
- platform: rest
resource: http://192.168.1.4/api/v2.0/system/info
headers:
scan_interval: 3600
json_attributes:
- uptime_seconds
- version
- model
- cores
## template sensors that extract state_attr
sensors:
## NAS Uptime seconds
tn_uptime_seconds:
friendly_name: "Uptime seconds"
value_template: "{{ state_attr('sensor.tn_info', 'uptime_seconds') }}"
## NAS Uptime seconds nice
tn_uptime:
value_template: >-
{%- set uptime = states.sensor.tn_uptime_seconds.state | round -%}
{%- set sep = ', ' -%}
{%- set TIME_MAP = {
'week': (uptime / 10080) % 10080,
'day': (uptime / 1440) % 7,
'hour': (uptime / 60) % 24,
'minute': (uptime % 60)
{%- for unit, duration in TIME_MAP.items() if duration >= 1 -%}
{%- if not loop.first -%}
{{ sep }}
{%- endif -%}
{{ (duration | string).split('.')[0] }} {{ unit }}
{%- if duration >= 2 -%}
s
{%- endif -%}
{%- endfor -%}
{%- if uptime < 1 -%}
just now
{%- endif -%}
## NAS Version
tn_version:
value_template: "{{ state_attr('sensor.tn_info', 'version') }}"
## CPU model
tn_cpu_model:
value_template: "{{ state_attr('sensor.tn_info', 'model') }}"
## CPU num of cores
tn_cpu_cores:
value_template: "{{ state_attr('sensor.tn_info', 'cores') }}"
- platform: rest
resource: http://192.168.1.4/api/v2.0/reporting/get_data
headers:
scan_interval: 60
method: POST
payload: >-
json_attributes:
- aggregations
value_template: >-
{% set tn = namespace(temp=0, cores=4) %}
{% endfor %}
## Alerts. Error if response is empty.
- platform: rest
headers:
scan_interval: 300
json_attributes:
- level
- formatted
value_template: >
{% else %}
{{ "None" }}
{% endif %}
sensors:
## Alert message
tn_alert_message:
# Disk temps
- platform: rest
method: POST
resource: http://192.168.1.4/api/v2.0/disk/temperatures
headers:
scan_interval: 300
payload: '{"names":["ada0","ada1","ada2"]}'
json_attributes:
- ada0
- ada1
- ada2
sensors:
tn_ada0_temperature:
value_template: '{{ state_attr("sensor.tn_disk_temp", "ada0") }}'
tn_ada1_temperature:
value_template: '{{ state_attr("sensor.tn_disk_temp", "ada1") }}'
tn_ada2_temperature:
value_template: '{{ state_attr("sensor.tn_disk_temp", "ada2") }}'
# Storage percentage
- platform: rest
resource: http://192.168.1.4/api/v2.0/pool/id/1
headers:
json_attributes:
- allocated
- size
scan_interval: 1800
sensors:
tn_pool_pct_used:
friendly_name: "% Used"
value_template: ' {{ (state_attr("sensor.tn_pool", "allocated") / state_attr("sensor.tn_pool", "size") * 100) | round(1) }} '
The CPU temperature request and handling is quite cumbersome. I’m glad you figured it out and shared it!
I’ve tried looking at the online API documentation to find an easier to use endpoint for this information, but it loads soooo slowly and often crashes my browser.
I definitely can’t take credit for any of it.
The cpu temperature part was posted by @troy.
hello reven! A true newbie here. First of all, Thanks you all very much for making things easier, and I apologize in advance for not being on your level. I’d like to know if you could help me get some information to make it work. The information I don’t understand is where do you get the api key for authorization? do you have to configure something in freenas? I tried to follow the steps but English is not my native language, so I got lost.
Welcome @nani_silverstone
TrueNAS 12.0 and later has the ability to use API keys instead of login credentials. Unfortunately, there is no way to use the API key on FreeNAS 11.3.
Here’s the link for the TrueNAS docs
Basically
To create an API key, open the [ TrueNAS ] web interface
(Settings) menu and click API KEY .
Click Add , enter a new key name, and click Add again to confirm. Immediately after the API key is created, you can use the key locally by clicking Copy to Clipboard . The API key can only be copied immediately after creation. When the initial creation window is closed, the API key cannot be copied again.
EDIT: For those still using FreeNAS 11.3, I have modified the # General info sensor from @reven great example, to show how you can use login credentials instead of an API Key.
# General info
- platform: rest
authentication: basic
username: !secret tn_user
password: !secret tn_passwd
headers:
scan_interval: 3600
json_attributes:
- uptime_seconds
- version
- model
- cores
71/5000
Thank you very much for the quick answer!!! I will try these days
Thanks @reven, brilliant stuff.
Mostly working here though I was unable to get the alert message to show content for some reason.
Oh, and for others confused with using API keys, you need to make sure it’s precursered with “Bearer”.
So for myself I set my tn_api_key variable to something like:
tn_api_key: Bearer 1-SomerandomAPIkeystringthing
EDIT: okay so found the reason for the missing alert message, my current warning message of pools eligible for upgrade was more than the 255 character limit allowed for a sensor state. Something to keep in mind.
