Freenove ESP32-WROVER Camera
Hi Everyone,
I have been struggling with the quality of the stream in ESPHome when I integrate the camera. With Arduino IDE, if I upload a sketch (CameraWebServer or VideoWebServer) and set the xclk frequency to 23hz, the camera runs perfectly. I can even stream at SVGA without any issues and get roughly 20fps. However, in ESPHOME, I can only set the xclk to 20hz and the stream is very laggy.
Any help would be greatly appreciated.
Cheers!
Code for your device?
There is a hack to get esphome to run at another speed, with good results. If I find the thread, I’ll let you know. In the meantime, search away.
EDIT: here ESP32 Camera Buffer Space / API disconnects - #5 by diplix
Alas, I saw that post in my previous search and tried it… Doesn’t seems to applied to the board I’m using, which utilize the esp32-wrover-kit. Only when I bump the xclk above 23Hz that it perform with a decent frame rate (done through Arduino IDE instead of ESPHome).
By code, do you mean ESP32-WROVER-E?
Here’s a summary of the board:
  • ESP32-Wrover-E Chip with 4MB PSRAM
  • Built-in USB-to-UART (CH340C drivers) — no need for an FTDI programmer
  • Camera OV2640 2 Megapixel
  • BOOT and RST buttons
  • LED indicators (RX/TX ON/OFF, and built-in LED (GPIO2))
  • Onboard antenna
Freenove ESP32-WROVER Board (bought mine without the SIM card as I didn’t need it for my project).
By code I think he meant your yaml which generated your firmware.
To which I’d add your logs…
Good catch! I’ll post it up…
esphome:
  friendly_name: ESP32 Cam
esp32:
  board: esp-wrover-kit
  framework:
    type: arduino
    version: recommended
# Example configuration entry
esp32_camera:
  external_clock:
    pin: GPIO21
    frequency: 16MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  data_pins: [GPIO4, GPIO5, GPIO18, GPIO19, GPIO36, GPIO39, GPIO34, GPIO35]
  vsync_pin: GPIO25
  href_pin: GPIO23
  pixel_clock_pin: GPIO22
  # Image Quality
  resolution: VGA
  jpeg_quality: 10
#  aec2: True
#  aec_mode: AUTO
#  max_framerate: 6 fps
#  idle_framerate: 0.1 fps
#  wb_mode: home
#  agc_gain_ceiling: 8x
#  vertical_flip: False
#  horizontal_mirror: False
esp32_camera_web_server:
  - port: 8080
    mode: Stream
  - port: 8081
    mode: snapshot
Currently at 16Hz on xclk, but tried from 8Hz up to 20Hz and the experience is the same…
I had the same issues, I have a Freenove ESP Starter Kit that comes with a ESP32 Wrover E.
Using the demo software the Camera worked fine but with ESPHome the picture was black or faint at best. I finally found setting the agc_mode to manual with agc_value to 8 fixed the issues.
Hope this helps somebody else spent 4 hours trying to fix this and almost gave up.
Would you be willing to paste your .yaml code? I’m currently in the midst of trouble shooting the same board.
Can we see that Yaml code? I’m about to chuck my freenove wrover-e in the trash.
I wrestled with this forever and finally got it to work.
  friendly_name: Cam1
esp32:
  framework:
    type: esp-idf
logger:
  level: INFO
esp32_camera:
  external_clock:
    pin: GPIO21
    frequency: 16MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  vsync_pin: GPIO25
  href_pin: GPIO23
  resolution: VGA
  jpeg_quality: 10
  max_framerate: 5 fps
  idle_framerate: .5 fps
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: none
  output_power: 17dB
  manual_ip:
    static_ip: 192.168.1.231
    gateway: 192.168.1.1
    subnet: 255.255.255.0
captive_portal:
