FreePBX Coustom Extension to call Home Assist?
Is there a way to create a extension in FreePBX that calls the voice assist?
Yes, this is possible. Go to FreePBX > Connectivity > Trunks > Add Trunk > Add SIP (chan_pjsip) Trunk to create a new trunk. Under the General page, you can leave everything as default. Under pjsip Settings, set Authentication to None and Registration to None. Set the SIP Server as your Home Assistant IP and 5060 as the SIP Server Port. Use a transport that does normal UDP.
Under the Advanced tab of the pjsip Settings, set the Qualify Frequency to 0 which disables the SIP OPTIONS PING functionality (based on my testing, Home Assistant doesn’t respond SIP OPTIONS PING. Under the Codecs tab ensure that only Opus is ticked.
Now you just need to create a new Outbound Route pointing to your new trunk and use any Dial Pattern. The first time you call, Home Assistant will prompt you to continue setup in the settings. You can then enable the FreePBX client from there.
i have attempted this but cant get it to work, not sure why. when i try to dial the number it just says invalid number or decline. any ideas?
