I too have a Frient energy monitor, well I actually have 3. I have several solar arrays and I’m using then to read my solar production
Each monitor reports POWER, ENERGY & LINK QUALITY
They initialyy appeared to be working perfectly but after a few days I noticed the increasing energy figure in kWh is very slowly drifting up (increasing) and so no longer matches the figure displayed on my meters.
I’ve been unable to change (SET) any parameters for the meters via MQTT so have set up some template sensors to allow me to adjust the kWh figures but then they slowly drift again
I have a very similar piece of equipment on my electricity meter which is made by Current Cost (Current Cost OptiSmart) which I use with a custom integration and that keeps in sync perfectly but these pieces of equipment are no longer available
I read earlier in this thread somewhere that that someone thought it may get a spike when re starting HA, does anyone have any more evidence of this and or a work around
My meters are running in their default mode of 1000 imp/kwh, I’m running the latest version of HA ( 2022.4.7) on a Raspberry Pi 4
[Device Support Request] Freint Electricity Meter Interface (Develco ZHEMI101)
**Is your feature request related to a problem? Please describe.** I believe th…at the Freint Electricity Meter Interface (Develco ZHEMI101) is already somewhat supported, meaning I can add it to my Home Assistant via ZHA. However, not all sensors and functionality is present.... **Describe the solution you'd like** 1. It appears that the battery sensor is supported but does get get exposed via ZHA. According to the manual, there is a status attribute on the metering cluster for reporting “Low battery”. 2. The device supports changing the ```PulseConfiguration``` from the default ```1000``` to something else such as ```3200```. However, changing this in Home Assistant does not save and the default ```1000` remains. 3. Upon adding the device, it exposes a ```Devicetemperature``` sensor. There is no features to allow the monitoring of the device. <details> <summary>Device signature</summary> ```yaml { "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.0: 0>, mac_capability_flags=<MACCapabilityFlags.NONE: 0>, manufacturer_code=0, maximum_buffer_size=0, maximum_incoming_transfer_size=0, server_mask=0, maximum_outgoing_transfer_size=0, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=False, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)", "endpoints": { "1": { "profile_id": 49353, "device_type": "0x0001", "in_clusters": [ "0x0002", "0x0003", "0x0005" ], "out_clusters": [ "0x0001" ] }, "2": { "profile_id": 260, "device_type": "0x0007", "in_clusters": [ "0x0000", "0x0003", "0x0702" ], "out_clusters": [ "0x000a" ] } }, "manufacturer": "Develco", "model": "ZHEMI101", "class": "zigpy.device.Device" } ``` marks. ``` </details> <details> <summary>Diagnostic information</summary> ```yaml { "home_assistant": { "installation_type": "Home Assistant Container", "version": "2022.8.0", "dev": false, "hassio": false, "virtualenv": false, "python_version": "3.10.5", "docker": true, "arch": "x86_64", "timezone": "Europe/London", "os_name": "Linux", "os_version": "5.10.0-16-amd64", "run_as_root": true }, "custom_components": { "eufy_vacuum": { "version": "1.0.4", "requirements": [ "cryptography" ] }, "adaptive_lighting": { "version": "1.0.14", "requirements": [] }, "auth_header": { "version": "1.4", "requirements": [] }, "dyson_local": { "version": "0.16.4-4", "requirements": [ "libdyson==0.8.11" ] } }, "integration_manifest": { "domain": "zha", "name": "Zigbee Home Automation", "config_flow": true, "documentation": "https://www.home-assistant.io/integrations/zha", "requirements": [ "bellows==0.31.2", "pyserial==3.5", "pyserial-asyncio==0.6", "zha-quirks==0.0.78", "zigpy-deconz==0.18.0", "zigpy==0.48.0", "zigpy-xbee==0.15.0", "zigpy-zigate==0.9.0", "zigpy-znp==0.8.1" ], "usb": [ { "vid": "10C4", "pid": "EA60", "description": "*2652*", "known_devices": [ "slae.sh cc2652rb stick" ] }, { "vid": "10C4", "pid": "EA60", "description": "*sonoff*plus*", "known_devices": [ "sonoff zigbee dongle plus" ] }, { "vid": "10C4", "pid": "EA60", "description": "*tubeszb*", "known_devices": [ "TubesZB Coordinator" ] }, { "vid": "1A86", "pid": "7523", "description": "*tubeszb*", "known_devices": [ "TubesZB Coordinator" ] }, { "vid": "1A86", "pid": "7523", "description": "*zigstar*", "known_devices": [ "ZigStar Coordinators" ] }, { "vid": "1CF1", "pid": "0030", "description": "*conbee*", "known_devices": [ "Conbee II" ] }, { "vid": "10C4", "pid": "8A2A", "description": "*zigbee*", "known_devices": [ "Nortek HUSBZB-1" ] }, { "vid": "0403", "pid": "6015", "description": "*zigate*", "known_devices": [ "ZiGate+" ] }, { "vid": "10C4", "pid": "EA60", "description": "*zigate*", "known_devices": [ "ZiGate" ] }, { "vid": "10C4", "pid": "8B34", "description": "*bv 2010/10*", "known_devices": [ "Bitron Video AV2010/10" ] } ], "codeowners": [ "@dmulcahey", "@adminiuga", "@puddly" ], "zeroconf": [ { "type": "_esphomelib._tcp.local.", "name": "tube*" }, { "type": "_zigate-zigbee-gateway._tcp.local.", "name": "*zigate*" } ], "after_dependencies": [ "onboarding", "usb", "zeroconf" ], "iot_class": "local_polling", "loggers": [ "aiosqlite", "bellows", "crccheck", "pure_pcapy3", "zhaquirks", "zigpy", "zigpy_deconz", "zigpy_xbee", "zigpy_zigate", "zigpy_znp" ], "is_built_in": true }, "data": { "ieee": "**REDACTED**", "nwk": 37751, "manufacturer": "Develco", "model": "ZHEMI101", "name": "Develco ZHEMI101", "quirk_applied": false, "quirk_class": "zigpy.device.Device", "manufacturer_code": 0, "power_source": "Battery or Unknown", "lqi": 255, "rssi": -49, "last_seen": "2022-08-04T20:46:32", "available": true, "device_type": "EndDevice", "signature": { "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.0: 0>, mac_capability_flags=<MACCapabilityFlags.NONE: 0>, manufacturer_code=0, maximum_buffer_size=0, maximum_incoming_transfer_size=0, server_mask=0, maximum_outgoing_transfer_size=0, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=False, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)", "endpoints": { "1": { "profile_id": 49353, "device_type": "0x0001", "in_clusters": [ "0x0002", "0x0003", "0x0005" ], "out_clusters": [ "0x0001" ] }, "2": { "profile_id": 260, "device_type": "0x0007", "in_clusters": [ "0x0000", "0x0003", "0x0702" ], "out_clusters": [ "0x000a" ] } } }, "active_coordinator": false, "entities": [ { "entity_id": "sensor.develco_zhemi101_smartenergymetering", "name": "Develco ZHEMI101" }, { "entity_id": "sensor.develco_zhemi101_smartenergysummation", "name": "Develco ZHEMI101" } ], "neighbors": [], "endpoint_names": [ { "name": "COMBINED_INTERFACE" }, { "name": "unknown 1 device_type of 0xc0c9 profile id" } ], "user_given_name": null, "device_reg_id": "6a43a27cb395251a11ce4663ac33c030", "area_id": "cupboard", "cluster_details": { "2": { "device_type": { "name": "COMBINED_INTERFACE", "id": 7 }, "profile_id": 260, "in_clusters": { "0x0000": { "endpoint_attribute": "basic", "attributes": { "0x0004": { "attribute_name": "manufacturer", "value": "Develco" }, "0x0005": { "attribute_name": "model", "value": "ZHEMI101" } }, "unsupported_attributes": {} }, "0x0003": { "endpoint_attribute": "identify", "attributes": {}, "unsupported_attributes": {} }, "0x0702": { "endpoint_attribute": "smartenergy_metering", "attributes": { "0x0000": { "attribute_name": "current_summ_delivered", "value": 0 }, "0x0100": { "attribute_name": "current_tier1_summ_delivered", "value": 281474976710655 }, "0x0102": { "attribute_name": "current_tier2_summ_delivered", "value": 281474976710655 }, "0x0200": { "attribute_name": "status", "value": 0 }, "0x0300": { "attribute_name": "unit_of_measure", "value": 0 }, "0x0301": { "attribute_name": "multiplier", "value": 1 }, "0x0302": { "attribute_name": "divisor", "value": 1000 }, "0x0303": { "attribute_name": "summation_formatting", "value": 251 }, "0x0304": { "attribute_name": "demand_formatting", "value": 251 }, "0x0306": { "attribute_name": "metering_device_type", "value": 0 }, "0x0400": { "attribute_name": "instantaneous_demand", "value": 0 } }, "unsupported_attributes": {} } }, "out_clusters": { "0x000a": { "endpoint_attribute": "time", "attributes": {}, "unsupported_attributes": {} } } }, "1": { "device_type": { "name": "unknown", "id": 1 }, "profile_id": 49353, "in_clusters": { "0x0002": { "endpoint_attribute": "device_temperature", "attributes": {}, "unsupported_attributes": {} }, "0x0003": { "endpoint_attribute": "identify", "attributes": {}, "unsupported_attributes": {} }, "0x0005": { "endpoint_attribute": "scenes", "attributes": {}, "unsupported_attributes": {} } }, "out_clusters": { "0x0001": { "endpoint_attribute": "power", "attributes": {}, "unsupported_attributes": {} } } } } } } ``` </details> ### **Additional context** **Manufacturer Product Page:** https://www.develcoproducts.com/products/meter-interfaces/external-meter-interface/ **Technical manual:** https://www.develcoproducts.com/media/1782/zhemi101-technical-manual-external-meter-interface.pdf ### **Extracts from Manual** **_Battery Information_** <img width="818" alt="Screenshot 2022-08-04 at 20 56 00" src="https://user-images.githubusercontent.com/46373533/182941150-56bfcdd8-a5bd-4acc-b646-d0121097a090.png"> _**Pulse Confirmation Information:**_ <img width="813" alt="Screenshot 2022-08-04 at 20 56 55" src="https://user-images.githubusercontent.com/46373533/182941278-8f611bb6-e6ce-4b85-bb54-bfeec3a1aff9.png"> _**Pulse Confirmation in Home Assistant**_ _This does not save and the default remains present_ <img width="554" alt="Screenshot 2022-08-04 at 20 58 58" src="https://user-images.githubusercontent.com/46373533/182941579-1e2e1cfd-d8e3-4b1e-b715-fef70f22a7ec.png"> ### _**HA Reconfig**_ <img width="499" alt="Screenshot 2022-08-04 at 21 02 31" src="https://user-images.githubusercontent.com/46373533/182943306-0ec4a7e0-3a01-496c-9124-f929fce729a4.png"> ### Other info I saw zigbee2mqtt added support recently https://github.com/Koenkk/zigbee2mqtt/issues/8638
