French gas meter; Does it have a P1 port?
My French house is connected to the town gas network and I have a meter outside near the street. I’m aware of devices that can connect to the P1 ports of utility meters to report usage to Home Assistant. I can’t work out if my meter has such a port. It seems to have a pretty basic looking port on the side although it appears to only have two pins so doesn’t seem to be a P1 port which AFAIA is the same (?) as an RJ11 telephone connector.
I’ve attached photos of the meter and aforementioned port. There may be more under the cover but it doesn’t seem to come off particularly easily and I don’t want to damage it.
I think the meter is smart (despite its analogue display) so I’m hopeful it’s possible to extract the readings without having to resort to AI image processing.
Can anyone familiar with type of meter help?
A pic of the meter (only allowed 1 upload per post…)
Zillions of post on the French community forum… look for gazpar.
In short: this one sends pulses, you can add a button to it
Thanks @vingerha. I’ve been doing a bit of research and read a few blog posts:
https://www.sanglierlab.fr/2019/11/17/capteur-sans-fil-pour-compteur-de-gaz-gazpar/
I think I’ll give it a go and have ordered a wireless relay which I’ll try and use to send the pulses to an ESP32.
I’m a bit confused by what it means by “sending a pulse”. What is a pulse in this context? I was thinking if it’s just a dry contact that gets closed it will be easy to use this to trigger the relay. But the first post I linked seems to say it’s a sort of transistor, and I’d be afraid of sending a voltage into the meter for risk of frying something inside it.
Can anyone with more electronics knowledge than me suggest the best approach?
The french community post I linked just has the guy linking up the relay transmitter with a 9v battery to the meter port in series, whilst the blog post seems a lot more complex. There is a community comment where one user reports thinking they may have fried their meter. Any ideas?
I am not sure what you read but ESP is overkill, buy a simple ‘button’ (any protocol) and have it short-cut the connection via the gazpar cables instead of pressing the button
I already have an esp32 measuring my electricity usage so was planning on using the same device for the gas. But it’s not in range of the gas meter so am planning on using a wireless relay like the following to act as the “button”.
My main uncertainty is around wiring the relay’s transmitter to the gas meter. The example I read has it wired in series with a 9v battery but I want to make sure I won’t harm anything inside the meter with the battery’s voltage
I guess (?) the 9v is for signal strength, it still only does a dry contact with each 10l o fgas, wiring it to a (e.g. ikea) button will set you back 5-15 eur depending on protocol
