Hey,
I use Frenck’s doorbell project and its brilliant. Currently, i am having network issues and only thing that is working is rebooting the router every day during the night. However, when the doorbell looses connection and gains connection again it sets off the chime
is there a way to stop that happening?
Thanks in advance
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "xxxxxxxxxxx"
password: "xxxxxxxxx"
ap:
ssid: "Doorbell Fallback Hotspot"
password: "xxxxxxxxxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "xxxxxxxx"
ota:
web_server:
port: 80
# Sync time with Home Assistant.
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: Doorbell ESPHome Version
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
ssid:
bssid:
# Sensors with general information.
# Uptime sensor.
- platform: uptime
# WiFi Signal sensor.
- platform: wifi_signal
name: Doorbell WiFi Signal
update_interval: 60s
# Global to store the on/off state of the chime
globals:
- id: chime
type: bool
restore_value: true
initial_value: 'true'
# Exposed switches.
switch:
# Switch to restart the doorbell.
- platform: restart
# Switch to turn on/off the chime.
- platform: gpio
inverted: true
pin: GPIO0
# Switch to turn on/off chime when
# doorbell button is pushed.
# It creates a "virtual" switch based
# on a global variable.
name: Doorbell Chime Active
restore_state: false
turn_on_action:
- globals.set:
value: 'true'
turn_off_action:
- globals.set:
value: 'false'
lambda: |-
return id(chime);
# Binary sensor representing the
# Doorbell button push.
binary_sensor:
- platform: gpio
pin:
# Connected to GPIO on the ESP-01S.
number: GPIO2
mode: INPUT_PULLUP
inverted: true
filters:
# Small filter, to debounce the button press.
- delayed_on: 25ms
- delayed_off: 25ms
on_press:
# Only turn on the chime when it is active.
then:
if:
condition:
- switch.is_on: chime_active
then:
- switch.turn_on: relay
on_release:
# On release, turn of the chime.
- switch.turn_off: relay
