Few times in day esp8266 becomes unavailable and reconnect between 5min-22min.
Why it gets disconnected?
Please help
Please help
Hi, maybe change “discount” in title to disconnect. No it seems like a commercial
Can you show your yaml for the device? For instance, if you use mqtt but also have api in there, the api might reboot every 15 mins because it is not connected. How stable is the wifi? That too can cause connection loss and reboots. You might also want to take a look at the logs to see if there’s anything funny going on.
Here is my garage-switchboard.yaml
for generic ESP-12E shown below
esphome:
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
reboot_timeout: 180s
# reboot esp if disconnected to home assistant more than 180s
encryption:
key: "key-of-some-kind"
web_server:
port: 80
ota:
- platform: esphome
password: "key-of-some-kind"
wifi:
#multi-network
networks:
- ssid: mi-fi
password: key-of-some-kind
- ssid: GF
- ssid: Home-WiFi
# assign manual ip
manual_ip:
static_ip: 192.168.29.212
gateway: 192.168.29.1
subnet: 255.255.255.0
dns1: 192.168.29.1
dns2: 8.8.8.8
ap:
ssid: "Garage-Switchboard"
status_led:
pin: GPIO2
switch:
- platform: gpio
pin: GPIO4
inverted: true
- platform: gpio
pin: GPIO5
inverted: true
- platform: gpio
pin: GPIO13
inverted: true
- platform: gpio
name: "Staircase Light - Ground Floor"
pin: GPIO12
inverted: true
Here is HA logbook
Appart form these, I have 2 router haveing same wi-fi AP, called mi-fi
for ground-floor and 1st-floor
Last time it was reported as wifi-strength was -40dB
after wake from limbo at 3:20am 27.10.2024 ESP log file
INFO ESPHome 2024.9.2
INFO Reading configuration /config/garage-switchboard.yaml...
INFO Starting log output from 192.168.29.212 using esphome API
INFO Successfully connected to garage-switchboard @ 192.168.29.212 in 0.007s
INFO Successful handshake with garage-switchboard @ 192.168.29.212 in 2.481s
[21:49:19][I][app:100]: ESPHome version 2024.9.2 compiled on Oct 20 2024, 20:27:38
[21:49:20][C][status_led:019]: Status LED:
[21:49:20][C][status_led:020]: Pin: GPIO2
[21:49:20][C][wifi:600]: WiFi:
[21:49:20][C][wifi:428]: Local MAC: xx:xx:FB:CF:yy:zz
[21:49:20][C][wifi:433]: SSID: [redacted]
[21:49:20][C][wifi:436]: IP Address: 192.168.29.212
[21:49:20][C][wifi:439]: BSSID: [redacted]
[21:49:20][C][wifi:441]: Hostname: 'garage-switchboard'
[21:49:20][C][wifi:443]: Signal strength: -44 dB ▂▄▆█
[21:49:20][C][wifi:447]: Channel: 11
[21:49:20][C][wifi:448]: Subnet: 255.255.255.0
[21:49:20][C][wifi:449]: Gateway: 192.168.29.1
[21:49:20][C][wifi:450]: DNS1: 192.168.29.1
[21:49:20][C][wifi:451]: DNS2: 8.8.8.8
[21:49:20][C][logger:185]: Logger:
[21:49:20][C][logger:186]: Level: DEBUG
[21:49:20][C][logger:188]: Log Baud Rate: 115200
[21:49:20][C][logger:189]: Hardware UART: UART0
[21:49:20][C][switch.gpio:068]: GPIO Switch '1hp-Pump'
[21:49:20][C][switch.gpio:076]: Inverted: YES
[21:49:20][C][switch.gpio:090]: Restore Mode: always OFF
[21:49:20][C][switch.gpio:031]: Pin: GPIO4
[21:49:20][C][switch.gpio:068]: GPIO Switch '12/18/24V Adapter'
[21:49:20][C][switch.gpio:031]: Pin: GPIO5
[21:49:20][C][switch.gpio:068]: GPIO Switch 'Auxilary Socket'
[21:49:20][C][switch.gpio:031]: Pin: GPIO13
[21:49:20][C][switch.gpio:068]: GPIO Switch 'Staircase Light - Ground Floor'
[21:49:20][C][switch.gpio:031]: Pin: GPIO12
[21:49:20][C][web_server:145]: Web Server:
[21:49:20][C][web_server:146]: Address: 192.168.29.212:80
[21:49:20][C][mdns:116]: mDNS:
[21:49:20][C][mdns:117]: Hostname: garage-switchboard
[21:49:20][C][esphome.ota:073]: Over-The-Air updates:
[21:49:20][C][esphome.ota:074]: Address: 192.168.29.212:xxxx
[21:49:20][C][esphome.ota:075]: Version: 2
[21:49:20][C][esphome.ota:078]: Password configured
[21:49:20][C][safe_mode:018]: Safe Mode:
[21:49:20][C][safe_mode:019]: Boot considered successful after 60 seconds
[21:49:20][C][safe_mode:021]: Invoke after 10 boot attempts
[21:49:20][C][safe_mode:022]: Remain in safe mode for 300 seconds
[21:49:20][C][api:139]: API Server:
[21:49:20][C][api:140]: Address: 192.168.29.212:6053
[21:49:20][C][api:142]: Using noise encryption: YES
[21:49:34][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
Well the log seems ok. Capturing when it disconnects would be useful.
You had 3 other devices go unavailable at around the same time based on your first screenshot.
Are you sure this is an ESP issue and not something else? Are all those other devices using WiFi?
