2024-11-20 12:08:44.237 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ripple_energy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-20 12:08:44.249 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration solcast_solar which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-20 12:08:44.260 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration octopus_energy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-20 12:08:44.271 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-20 12:08:44.282 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration vaillant_vsmart which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-20 12:08:44.294 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-20 12:08:50.448 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-11-20 12:08:50.687 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=745 from 2024-11-20 11:51:58.112456)
2024-11-20 12:09:20.086 WARNING (MainThread) [homeassistant.components.homeassistant.triggers.numeric_state] Error initializing ‘Notification test’ trigger: In ‘numeric_state’ condition: unknown entity sensor.random_sensor
2024-11-20 12:09:20.676 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.agile_predict exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-11-20 12:09:24.717 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.agile_predict exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-11-20 12:38:29.069 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 12:38:29.230 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 12:38:29.231 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:09:11.038 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 12:38:29.231 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:09:11.039 INF config path=/tmp/go2rtc_y2f98w87.yaml
2024-11-20 12:38:29.232 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:09:11.041 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 12:38:29.233 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:09:11.041 INF [api] listen addr=127.0.0.1:11984
2024-11-20 12:38:29.234 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:09:11.043 INF [webrtc] listen addr=:18555/tcp
2024-11-20 12:38:29.234 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 12:40:18.790 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.octopus_energy_electricity_19l3416440_2000013980286_previous_accumulative_consumption is taking over 10 seconds
2024-11-20 12:40:18.806 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.octopus_energy_gas_e6s16178301861_3967109307_previous_accumulative_consumption_m3 is taking over 10 seconds
2024-11-20 12:45:21.557 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.givtcp_ce2105g064_load_energy_today_kwh from integration mqtt has state class total_increasing, but its state is not strictly increasing. Triggered by state 2.2 (2.3) with last_updated set to 2024-11-20T12:44:39.090509+00:00. Please create a bug report at Issues · home-assistant/core · GitHub
2024-11-20 12:45:21.644 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.givtcp_ce2105g064_load_energy_total_kwh from integration mqtt has state class total_increasing, but its state is not strictly increasing. Triggered by state 11832.2 (11832.3) with last_updated set to 2024-11-20T12:44:39.101454+00:00. Please create a bug report at Issues · home-assistant/core · GitHub
2024-11-20 12:48:44.744 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 12:48:44.864 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 12:48:44.865 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:38:30.230 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 12:48:44.866 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:38:30.265 INF config path=/tmp/go2rtc_zgz1jqxg.yaml
2024-11-20 12:48:44.866 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:38:30.269 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 12:48:44.866 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:38:30.269 INF [api] listen addr=127.0.0.1:11984
2024-11-20 12:48:44.867 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:38:30.271 INF [webrtc] listen addr=:18555/tcp
2024-11-20 12:48:44.867 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 12:51:47.372 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.octopus_energy_electricity_19l3416440_2000013980286_previous_accumulative_consumption (<class ‘custom_components.octopus_energy.electricity.previous_accumulative_consumption.OctopusEnergyPreviousAccumulativeElectricityConsumption’>) took 0.435 seconds. Please create a bug report at Issues · BottlecapDave/HomeAssistant-OctopusEnergy · GitHub
2024-11-20 12:54:36.822 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-11-20 12:54:36.826 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-11-20 12:54:36.835 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-11-20 12:54:36.837 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-11-20 12:54:36.839 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-11-20 12:54:36.840 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /network/info request
2024-11-20 12:54:43.307 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-11-20 12:54:43.410 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-11-20 12:54:43.413 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-11-20 12:54:43.418 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-11-20 12:54:43.525 WARNING (MainThread) [homeassistant.components.hassio] Can’t read Supervisor data:
2024-11-20 12:54:45.163 ERROR (MainThread) [homeassistant.components.hassio.coordinator] Error fetching hassio data: Error on Supervisor API:
2024-11-20 12:54:46.772 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 12:54:55.627 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc server didn’t terminate gracefully. Killing it
2024-11-20 12:54:56.048 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 12:54:56.179 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:48:45.997 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 12:54:56.180 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:48:45.997 INF config path=/tmp/go2rtc_jkn9oruf.yaml
2024-11-20 12:54:56.180 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:48:46.000 INF [api] listen addr=127.0.0.1:11984
2024-11-20 12:54:56.181 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:48:46.001 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 12:54:56.181 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:48:46.003 INF [webrtc] listen addr=:18555/tcp
2024-11-20 12:54:56.181 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 12:58:14.000 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 12:58:14.015 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 12:58:14.016 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:55:04.636 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 12:58:14.016 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:55:04.636 INF config path=/tmp/go2rtc_pkaxz0z9.yaml
2024-11-20 12:58:14.016 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:55:04.638 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 12:58:14.016 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:55:04.638 INF [api] listen addr=127.0.0.1:11984
2024-11-20 12:58:14.017 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:55:04.640 INF [webrtc] listen addr=:18555/tcp
2024-11-20 12:58:14.017 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:01:07.754 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:01:07.931 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 13:01:07.932 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:58:14.848 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 13:01:07.932 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:58:14.849 INF config path=/tmp/go2rtc_w5hxwq3k.yaml
2024-11-20 13:01:07.932 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:58:14.851 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 13:01:07.933 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:58:14.851 INF [api] listen addr=127.0.0.1:11984
2024-11-20 13:01:07.933 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:58:14.852 INF [webrtc] listen addr=:18555/tcp
2024-11-20 13:01:07.933 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:04:23.492 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:04:23.510 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 13:04:23.511 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:01:09.199 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 13:04:23.511 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:01:09.199 INF config path=/tmp/go2rtc__uezf12x.yaml
2024-11-20 13:04:23.512 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:01:09.201 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 13:04:23.512 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:01:09.201 INF [api] listen addr=127.0.0.1:11984
2024-11-20 13:04:23.512 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:01:09.204 INF [webrtc] listen addr=:18555/tcp
2024-11-20 13:04:23.513 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:05:52.416 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:05:52.442 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 13:05:52.443 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:04:24.602 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 13:05:52.443 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:04:24.603 INF config path=/tmp/go2rtc_gzke4yyg.yaml
2024-11-20 13:05:52.444 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:04:24.606 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 13:05:52.445 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:04:24.606 INF [api] listen addr=127.0.0.1:11984
2024-11-20 13:05:52.446 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:04:24.607 INF [webrtc] listen addr=:18555/tcp
2024-11-20 13:05:52.446 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:06:32.578 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:06:32.610 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 13:06:32.610 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:05:53.564 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 13:06:32.611 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:05:53.564 INF config path=/tmp/go2rtc_4vupen7o.yaml
2024-11-20 13:06:32.611 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:05:53.566 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 13:06:32.611 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:05:53.566 INF [api] listen addr=127.0.0.1:11984
2024-11-20 13:06:32.611 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:05:53.567 INF [webrtc] listen addr=:18555/tcp
2024-11-20 13:06:32.612 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:09:01.848 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /backups request
2024-11-20 13:09:03.141 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /backups -
2024-11-20 13:09:20.682 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.octopus_energy_gas_e6s16178301861_3967109307_current_rate (<class ‘custom_components.octopus_energy.gas.current_rate.OctopusEnergyGasCurrentRate’>) took 0.404 seconds. Please create a bug report at Issues · BottlecapDave/HomeAssistant-OctopusEnergy · GitHub
2024-11-20 13:09:26.667 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.octopus_energy_gas_e6s16178301861_3967109307_previous_rate (<class ‘custom_components.octopus_energy.gas.previous_rate.OctopusEnergyGasPreviousRate’>) took 0.938 seconds. Please create a bug report at Issues · BottlecapDave/HomeAssistant-OctopusEnergy · GitHub
2024-11-20 13:09:37.037 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons request
2024-11-20 13:09:37.588 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons -
2024-11-20 13:09:38.278 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-11-20 13:09:38.279 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /host/info -
2024-11-20 13:09:59.097 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for event.octoplus_saving_session_events_a_3c7c194c (<class ‘custom_components.octopus_energy.octoplus.saving_sessions_events.OctopusEnergyOctoplusSavingSessionEvents’>) took 2.050 seconds. Please create a bug report at Issues · BottlecapDave/HomeAssistant-OctopusEnergy · GitHub
2024-11-20 13:10:02.370 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for event.octopus_energy_electricity_19l3416440_2000013980286_previous_day_rates (<class ‘custom_components.octopus_energy.electricity.rates_previous_day.OctopusEnergyElectricityPreviousDayRates’>) took 0.886 seconds. Please create a bug report at Issues · BottlecapDave/HomeAssistant-OctopusEnergy · GitHub
2024-11-20 13:10:14.122 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.agile_predict is taking over 10 seconds
2024-11-20 13:10:37.970 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.octopus_energy_a_3c7c194c_octoplus_points is taking over 10 seconds
2024-11-20 13:10:44.369 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.rpi_power_status is taking over 10 seconds
2024-11-20 13:11:21.773 WARNING (MainThread) [homeassistant.components.sensor] Updating octopus_energy sensor took longer than the scheduled update interval 0:00:30
2024-11-20 13:11:29.031 ERROR (MainThread) [homeassistant.components.rest.data] Error fetching data: Price Forecast Region Api – Django REST framework failed with [Errno -3] Try again
2024-11-20 13:11:29.113 WARNING (MainThread) [homeassistant.components.rest.util] Empty reply found when expecting JSON data
2024-11-20 13:11:29.276 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-11-20 13:11:29.310 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-11-20 13:11:29.315 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-11-20 13:11:29.318 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-11-20 13:11:29.321 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-11-20 13:11:29.323 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /network/info request
2024-11-20 13:11:29.325 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc server didn’t terminate gracefully. Killing it
2024-11-20 13:11:29.326 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 13:11:29.326 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:06:33.856 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 13:11:29.326 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:06:33.857 INF config path=/tmp/go2rtc_srddrbuz.yaml
2024-11-20 13:11:29.327 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:06:33.862 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 13:11:29.327 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:06:33.862 INF [api] listen addr=127.0.0.1:11984
2024-11-20 13:11:29.327 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:06:33.863 INF [webrtc] listen addr=:18555/tcp
2024-11-20 13:11:33.379 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:11:36.242 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-11-20 13:11:36.330 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-11-20 13:11:48.891 WARNING (MainThread) [homeassistant.components.hassio] Can’t read Supervisor data:
2024-11-20 13:12:19.604 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-11-20 13:13:39.252 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-11-20 13:13:46.988 ERROR (MainThread) [homeassistant.components.hassio.coordinator] Error fetching hassio data: Error on Supervisor API:
2024-11-20 13:13:51.134 WARNING (MainThread) [homeassistant.components.sensor] Updating octopus_energy sensor took longer than the scheduled update interval 0:00:30
2024-11-20 13:14:43.530 WARNING (MainThread) [homeassistant.components.sensor] Updating octopus_energy sensor took longer than the scheduled update interval 0:00:30
2024-11-20 13:14:43.652 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from supervisor (172.30.32.2). Requested URL: ‘/api/core/state’. (HomeAssistantSupervisor/2024.11.2 aiohttp/3.10.10 Python/3.12)
2024-11-20 13:14:43.834 ERROR (MainThread) [kasa.smart.smartdevice] Error querying 192.168.0.23 for modules ‘AutoOff, DeviceModule, Energy, Time’ after first update: ('Unable to query the device, timed out: 192.168.0.23: ', TimeoutError())
2024-11-20 13:14:43.843 WARNING (MainThread) [custom_components.octopus_energy.api_client] Failed to connect. Timeout of ClientTimeout(total=None, connect=None, sock_read=20, sock_connect=20, ceil_threshold=5) exceeded.
2024-11-20 13:14:43.844 WARNING (MainThread) [custom_components.octopus_energy.octoplus.points] Failed to retrieve octopoints
2024-11-20 13:14:44.125 WARNING (MainThread) [custom_components.octopus_energy.api_client] Failed to connect. Timeout of ClientTimeout(total=None, connect=None, sock_read=20, sock_connect=20, ceil_threshold=5) exceeded.
2024-11-20 13:14:44.160 WARNING (MainThread) [custom_components.octopus_energy.coordinators.current_consumption] Failed to retrieve smart meter consumption data - using cached version. Next attempt at 2024-11-20 13:10:07.730222+00:00
2024-11-20 13:14:44.184 WARNING (MainThread) [custom_components.octopus_energy.api_client] Failed to connect. Timeout of ClientTimeout(total=None, connect=None, sock_read=20, sock_connect=20, ceil_threshold=5) exceeded.
2024-11-20 13:14:44.185 WARNING (MainThread) [custom_components.octopus_energy.coordinators.current_consumption] Failed to retrieve smart meter consumption data - using cached version. Next attempt at 2024-11-20 13:10:10.342199+00:00
2024-11-20 13:14:44.201 WARNING (MainThread) [custom_components.octopus_energy.api_client] Failed to connect. Timeout of ClientTimeout(total=None, connect=None, sock_read=20, sock_connect=20, ceil_threshold=5) exceeded.
2024-11-20 13:14:44.202 WARNING (MainThread) [custom_components.octopus_energy.coordinators.previous_consumption_and_rates] Failed to retrieve previous consumption data for gas 3967109307/E6S16178301861 - using cached data. Next attempt at 2024-11-20 13:11:06.111490+00:00. Exception:
2024-11-20 13:14:44.207 WARNING (MainThread) [custom_components.octopus_energy.api_client] Failed to connect. Timeout of ClientTimeout(total=None, connect=None, sock_read=20, sock_connect=20, ceil_threshold=5) exceeded.
2024-11-20 13:14:44.208 WARNING (MainThread) [custom_components.octopus_energy.coordinators.previous_consumption_and_rates] Failed to retrieve previous consumption data for electricity 2000013980286/19L3416440 - using cached data. Next attempt at 2024-11-20 13:11:05.807879+00:00. Exception:
2024-11-20 13:14:44.240 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from supervisor (172.30.32.2). Requested URL: ‘/api/core/state’. (HomeAssistantSupervisor/2024.11.2 aiohttp/3.10.10 Python/3.12)
2024-11-20 13:15:28.346 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:15:28.741 WARNING (MainThread) [homeassistant.components.go2rtc.server] Go2rtc unexpectedly stopped, server log:
2024-11-20 13:15:28.743 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:15:28.743 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:11:53.603 INF go2rtc platform=linux/arm64 revision=dbe9e4a version=1.9.7
2024-11-20 13:15:28.744 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:11:53.634 INF config path=/tmp/go2rtc_9mt1d9vp.yaml
2024-11-20 13:15:28.745 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:11:53.637 INF [rtsp] listen addr=127.0.0.1:18554
2024-11-20 13:15:28.746 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:11:53.637 INF [api] listen addr=127.0.0.1:11984
2024-11-20 13:15:28.746 WARNING (MainThread) [homeassistant.components.go2rtc.server] 13:11:53.638 INF [webrtc] listen addr=:18555/tcp
2024-11-20 13:15:28.747 WARNING (MainThread) [homeassistant.components.go2rtc.server] exit with signal: terminated
2024-11-20 13:15:37.890 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.octopus_energy_electricity_19l3416440_2000013980286_previous_accumulative_consumption is taking over 10 seconds
2024-11-20 13:15:38.043 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.octopus_energy_gas_e6s16178301861_3967109307_previous_accumulative_consumption_m3 is taking over 10 seconds
2024-11-20 13:15:51.719 ERROR (MainThread) [homeassistant.components.go2rtc.server] Unexpected error when restarting go2rtc server
File “/usr/local/lib/python3.12/site-packages/aiohttp/client.py”, line 663, in _request
conn = await self._connector.connect(
File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 538, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1050, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1353, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1109, in _wrap_create_connection
sock = await aiohappyeyeballs.start_connection(
File “/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py”, line 89, in start_connection
sock, _, _ = await _staggered.staggered_race(
File “/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/_staggered.py”, line 160, in staggered_race
done = await _wait_one(
File “/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/_staggered.py”, line 41, in _wait_one
return await wait_next
asyncio.exceptions.CancelledError
File “/usr/src/homeassistant/homeassistant/components/go2rtc/server.py”, line 190, in _watchdog
await self._start()
File “/usr/src/homeassistant/homeassistant/components/go2rtc/server.py”, line 137, in _start
await client.validate_server_version()
File “/usr/local/lib/python3.12/site-packages/go2rtc_client/exceptions.py”, line 56, in _func
return await func(*args, **kwargs)
File “/usr/local/lib/python3.12/site-packages/go2rtc_client/rest.py”, line 150, in validate_server_version
application_info = await self.application.get_info()
File “/usr/local/lib/python3.12/site-packages/go2rtc_client/rest.py”, line 74, in get_info
resp = await self._client.request(“GET”, self.PATH)
File “/usr/local/lib/python3.12/site-packages/go2rtc_client/rest.py”, line 55, in request
resp = await self._session.request(method, url, **kwargs)
File “/usr/local/lib/python3.12/site-packages/aiohttp/client.py”, line 578, in _request
with timer:
File “/usr/local/lib/python3.12/site-packages/aiohttp/helpers.py”, line 749, in exit
raise asyncio.TimeoutError from exc_val
TimeoutError
2024-11-20 13:15:52.514 WARNING (MainThread) [homeassistant.components.sensor] Updating octopus_energy sensor took longer than the scheduled update interval 0:00:30
