Hi there!
I’m playing around with a soil moisture sensor in combination with a small pump.
The goal is to automatically water my plant when the soil moisture voltage reaches a certain threshold (pump on) and stop the pump again when another threshold has been reached.
I’ve set the update_interval of the soil moisture sensor to 1second. The soil moisture sensor updates very quickly and the pump gets stopped in time before the soil gets too wet.
The only downside of this approach is that the device is also sending updates to home assistant every second. This is a bit too much, since the values would not change that quickly if the pump is not on.
I tried the sliding_window_moving_average
configuration and I hoped it would use the value for turning on / off the pump without sending updates to home assistant. But unfortunately this is not working in the way that I expected.
How can I turn on / off the pump (switch) on the device but only send out updates every couple of minutes to home assistant?
