Hi all
Probably yet another question about the inability to access HA after installing it on Docker.
I ran this command, as described in the installation guide:
docker run -d --name="home-assistant" -v /media/HA:/config -v /etc/localtime:/etc/localtime:ro --net=host --restart=always homeassistant/home-assistant:stable
Firewall is set to ACCEPT, so no blocking there.
It shows as running:
*CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES*
*ef12f6887980 homeassistant/home-assistant:stable "/init" 10 minutes ago Up 10 minutes home-assistant*
*83145661d809 portainer/portainer "/portainer" 31 minutes ago Up 31 minutes 0.0.0.0:8000->8000/tcp, 0.0.0.0:9000->9000/tcp portainer*
However, when I’m trying to reach http(s)://ipofclient:8123 it times out. Other applications on that platform run just fine, I can access it through SSH easily as well.
The config folder in question is properly filled on installation as well:
ls HA
automations.yaml configuration.yaml deps groups.yaml home-assistant_v2.db scenes.yaml scripts.yaml secrets.yaml tts
Docker logs are the following:
2020-07-28T16:41:22.473831081Z [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
2020-07-28T16:41:22.502870224Z [s6-init] ensuring user provided files have correct perms...exited 0.
2020-07-28T16:41:22.503620434Z [fix-attrs.d] applying ownership & permissions fixes...
2020-07-28T16:41:22.504386889Z [fix-attrs.d] done.
2020-07-28T16:41:22.504881546Z [cont-init.d] executing container initialization scripts...
2020-07-28T16:41:22.505587125Z [cont-init.d] udev.sh: executing...
2020-07-28T16:41:22.528954596Z starting version 3.2.9
2020-07-28T16:41:22.531662747Z [18:41:22] INFO: Update udev information
2020-07-28T16:41:22.552615598Z [cont-init.d] udev.sh: exited 0.
2020-07-28T16:41:22.553293289Z [cont-init.d] done.
2020-07-28T16:41:22.553840838Z [services.d] starting services
2020-07-28T16:41:22.563754552Z [services.d] done.
Going into the console via Portainer works as well.
I’m at a loss, please help!
