Hi
I installed HA folllowing home-assistant-installation-proxmox which ended successfully. When starting HA some material was automatically detected, perfect.
Problem now is that addons list is empty. I also notice that supervisor is started very slowly, eg: 4~5 minutes before I can access GUI.
That was I used to install the VM. It doesn’t explain why from manual connection to addons is OK and why addons doesn’t appears as well as why supervisor takes so long time to be ready.
I reinstall with the link you gave by deleting the old VM and running the script: still problem exist, see attached print screen, connection reset by peer when trying to load addons
