Hey ya. Just having a bit of difficulty setting up cec control. I initially had it configured through hassio no worries until I could not longer view the front end. I then installed hassbian 1.3, carried out sudo apt-get update, upgrade, dist-upgrade and reboot. After that I used hassbian-config to install samba - no worries. installed libcec through the same means no worries. ssh returns the right information through the echo command listed on the /components/hdmi_cec/ page. I can even monitor the cec bus through ssh no worries. After I added hdmi_cec: to my config yaml, restarted home assistant, the below error appeared in the log. So i adjusted my entry as such:
hdmi_cec:
devices:
TV: 0.0.0.0
HT: 3.0.0.0
Same error is returned.
2017-09-17 03:25:47 ERROR (MainThread) [homeassistant.setup] Error during setup of component hdmi_cec
File "/srv/homeassistant/lib/python3.5/site-packages/cec/__init__.py", line 18, in swig_import_helper
return importlib.import_module(mname)
File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 986, in _gcd_import
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 956, in _find_and_load_unlocked
ImportError: No module named '_cec'
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/hdmi_cec.py", line 184, in setup
adapter = CecAdapter(name=display_name[:12], activate_source=False)
File "/srv/homeassistant/lib/python3.5/site-packages/pycec/cec.py", line 20, in __init__
import cec
File "/srv/homeassistant/lib/python3.5/site-packages/cec/__init__.py", line 21, in <module>
_cec = swig_import_helper()
File "/srv/homeassistant/lib/python3.5/site-packages/cec/__init__.py", line 20, in swig_import_helper
return importlib.import_module('_cec')
To be honest I have no idea what any of this means. My level of experience with linux is basically copy and pasting from the web which I realise isn’t ideal at all. Can anyone shed any light on my problem?
I’d love a solution though.
