While searching for info on this, I’m finding out about the three flavors of HA. I’ve never used that or knew about it before. I used just plain “Home Assistant” on the Raspberry Pi Imager. Could that be the problem? Did it download Green? And from what it says, can Yellow go on a microSD card or not?
So if I’ve just used the standard download on RasPi Imager in the past, which version should I use now?
I’ve been using this Samba Backup add-on for a long while and I haven’t had problems restoring the config in the past.
I’m also wondering if there could be an issue with the Pi. I had to do a reinstall because the last setup went bad. When I checked the console output, I had one error repeat over and over, scrolling so fast I could barely read, but it was a write error. I figured if I just re-installed on a new microSD card, I could restore a backup from the past week, but since I can’t even load one, even the earliest one on the screenshot I included, I’m wondering if there could be a problem with the Pi overall.
Agree 100%. I am NOT going to depend on a back on the system being backed up. Not for HA, not for my firewall, not for ANYTHING. The whole point of a backup is to have that data safe in case the system fails. Why keep it on the failed system?
I haven’t had to work with the HA config in a good while and don’t remember every detail of HA, pfSense, OctoPrint, RasPiOS, and all the other systems I use, so it took me a while to work through this. I installed Samba Share, then realized that was thee add-on to just provide a SMB share on the HA system, so I went looking for the Samba backup. I forgot I could add a repository and that made me wonder if I had used something not available for the “level” of HA I had installed.
When I found the page I linked to above, the pieces fell into place. I installed that add-on and restored from my NAS. Now it’s working.
I look forward to when the included backup feature allows backing up to a network share.
