Followed the installation steps for the image of the sim card but when I boot the Pi4B up on the Hassos_rpi4-3.7 disc image it goes through all the steps and then stops with a reoccurring same error as you see in the image
I tested the network is working it has the ip of 16.1.1.148 on the network I can ping it as well it knows I have take it out (as you can see in the last lines of the images.
DHCP severed up the ip address from our domain controller.
Seems like it whats a IPv6 address which i do not presently have enabled on the DHCP server.
The error has been reoccurring for about 3 hours while I was gone.
Its a private network so really doesn’t mater what address I use for the network, it leaves this network NAT’d so no one sees it anyway. For some reason I implemented it here about 15+ years ago… could have been when I worked for HP and I had some reason to do it. I do not believe this address space is causing the issue as the errors are based on IPv6 from what I read/understtand.
