Thanks to all for this fantastic collective system called Homeassistant.
Some time ago (1 year +) an update broke mqqt in my install. At the time I tried a purge/reinstall with luck, and gave up. Fast forward, and I just downloaded haos_ova-9.0.vdi.zip, spun up a new vbox vm the other day.
So I try, once again to install the Mosquitto broker Current version: 6.1.3 add-on, very carefully following the provided instructions, it seams to fail.
Follow these steps to get the add-on installed on your system:
Navigate in your Home Assistant frontend to Supervisor -> Add-on Store.
Find the "Mosquitto broker" add-on and click it.
Click on the "INSTALL" button. [u]DONE[/u]
How to use
The add-on has a couple of options available. To get the add-on running:
Start the add-on. [u]Done, but the green indicator (top right) remains red.[/u]
Have some patience and wait a couple of minutes.
Check the add-on log output to see the result.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[07:16:11] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[07:16:11] INFO: Starting NGINX for authentication handling...
[07:16:11] INFO: Starting mosquitto MQTT broker...
2022-10-13 07:16:11: Warning: Mosquitto should not be run as root/administrator.
[07:16:12] INFO: Successfully send discovery information to Home Assistant.
[07:16:12] INFO: Successfully send service information to the Supervisor.
2022-10-13 07:16:11: mosquitto version 2.0.11 starting
2022-10-13 07:16:11: Config loaded from /etc/mosquitto/mosquitto.conf.
2022-10-13 07:16:11: Loading plugin: /usr/share/mosquitto/go-auth.so
2022-10-13 07:16:11: ├── Username/password checking enabled.
2022-10-13 07:16:11: ├── TLS-PSK checking enabled.
2022-10-13 07:16:11: └── Extended authentication not enabled.
2022-10-13 07:16:11: Opening ipv4 listen socket on port 1883.
2022-10-13 07:16:11: Opening ipv6 listen socket on port 1883.
2022-10-13 07:16:11: Opening websockets listen socket on port 1884.
2022-10-13 07:16:11: mosquitto version 2.0.11 running
Create a new user for MQTT via your Home Assistant's frontend Configuration -> Users (manage users) , (i.e. not on Mosquitto's Configuration tab). Notes:
This name cannot be homeassistant or addons, those are reserved usernames.
If you do not see the option to create a new user, ensure that Advanced Mode is enabled in your Home Assistant profile. [u]DONE[/u]
To use the Mosquitto as a broker, go to the integration page and install the configuration with one click:
Navigate in your Home Assistant frontend to Configuration -> Integrations.
MQTT should appear as a discovered integration at the top of the page
Select it and check the box to enable MQTT discovery if desired, and hit submit.
[u]DONE[/u]
However the ‘active indicator’ never turns green. After setting some time there are further entries in the log.
2022-10-13 07:16:12: New connection from 127.0.0.1:40660 on port 1883.
2022-10-13 07:16:12: Client <unknown> closed its connection.
2022-10-13 07:16:51: New connection from 172.30.32.2:55596 on port 1883.
2022-10-13 07:16:51: Client <unknown> closed its connection.
2022-10-13 07:18:51: New connection from 172.30.32.2:33042 on port 1883.
2022-10-13 07:18:51: Client <unknown> closed its connection.
2022-10-13 07:20:51: New connection from 172.30.32.2:43328 on port 1883.
2022-10-13 07:20:51: Client <unknown> closed its connection.
2022-10-13 07:21:40: New connection from 172.30.32.1:43705 on port 1883.
2022-10-13 07:21:40: New client connected from 172.30.32.1:43705 as 2JVJh20AqaqqzQaEXl2rmT (p2, c1, k60, u'homeassistant').
2022-10-13 07:21:40: Client 2JVJh20AqaqqzQaEXl2rmT disconnected.
2022-10-13 07:21:40: New connection from 172.30.32.1:60571 on port 1883.
2022-10-13 07:21:40: New client connected from 172.30.32.1:60571 as 1jHqa4RoLDPvHltJFKA5ng (p2, c1, k60, u'homeassistant').
2022-10-13 07:22:14: New connection from 172.30.32.1:40957 on port 1883.
2022-10-13 07:22:14: New client connected from 172.30.32.1:40957 as 0KkPMFLctlFvL3B2GlUvlT (p1, c1, k60, u'homeassistant').
2022-10-13 07:22:14: Client 0KkPMFLctlFvL3B2GlUvlT disconnected.
2022-10-13 07:22:37: New connection from 172.30.32.1:39245 on port 1883.
2022-10-13 07:22:37: New client connected from 172.30.32.1:39245 as 352EnSV4XkZL2DXxKrnmdd (p2, c1, k60, u'homeassistant').
2022-10-13 07:22:51: New connection from 172.30.32.2:55468 on port 1883.
2022-10-13 07:22:51: Client <unknown> closed its connection.
I simply must conclude that there is something missing from the setup instructions.
I need mqqt because I have 4 feit switches and some light bulb that have tasmota installed on them. [Tasmota 11.0.0 by Theo Arends]
MQQT diagnostics
{ "home_assistant": { "installation_type": "Home Assistant OS", "version": "2022.10.3", "dev": false, "hassio": true, "virtualenv": false, "python_version": "3.10.5", "docker": true, "arch": "x86_64", "timezone": "America/Detroit", "os_name": "Linux", "os_version": "5.15.72", "supervisor": "2022.10.0", "host_os": "Home Assistant OS 9.2", "docker_version": "20.10.17", "chassis": "vm", "run_as_root": true }, "custom_components": { "hacs": { "version": "1.28.0", "requirements": [ "aiogithubapi>=22.2.4" ] }, "wyzeapi": { "version": "0.1.13", "requirements": [ "wyzeapy==0.5.12" ] } }, "integration_manifest": { "domain": "mqtt", "name": "MQTT", "config_flow": true, "documentation": "https://www.home-assistant.io/integrations/mqtt", "requirements": [ "paho-mqtt==1.6.1" ], "dependencies": [ "http" ], "codeowners": [ "@emontnemery" ], "iot_class": "local_push", "is_built_in": true }, "data": { "connected": true, "mqtt_config": { "birth_message": { "topic": "homeassistant/status", "payload": "online", "qos": 0, "retain": false }, "discovery": true, "port": 1883, "tls_version": "auto", "will_message": { "topic": "homeassistant/status", "payload": "offline", "qos": 0, "retain": false }, "keepalive": 60, "protocol": "3.1.1", "discovery_prefix": "homeassistant", "broker": "core-mosquitto", "username": "**REDACTED**", "password": "**REDACTED**" }, "devices": [], "mqtt_debug_info": { "entities": [], "triggers": [] } } }
I have changed the user/password of one FIET switch to the new one created above. No Joy
They were successfully flashed awhile ago and worked with some minor issues till the system was broken by the upgrade I was never able to get fixed.
Thanks again for your help.
