I’m trying a fresh install of ha on a headless rpi5.
I’ve used Rpi Imager on Win11 to create a SD disk (64GB)
After booting the rpi5 with network cable connected, I could connect to ha web GUI and watched the installer fail:
Can't install ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.3.0: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.3.0/json: Not Found ("No such image: ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.3.0")
24-03-10 13:25:04 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-03-10 13:25:34 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi5-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.3.0
24-03-10 13:25:34 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi5-64-homeassistant with tag 2024.3.0.
24-03-10 13:26:29 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.3.0: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.3.0/json: Not Found ("No such image: ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.3.0")
24-03-10 13:26:29 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
This loop repeats ad infinitum
The stupid thing is that Rpi imager doesn’t seem to support adding SSH access to the rpi5, so now what?
Yes, I can see it connected to my router. But because there’s no way to login to the rpi5 because there’s afaik no way to enable SSH access, I cannot tell for sure if it can access internet.
# docker pull ghcr.io/home-assistant/raspberrypi5-64-homeassistant:sha256-de7702643da7a48e9447cb82c18f9e86707517add6ce5e41ef6f3c053ff75dab.sig
sha256-de7702643da7a48e9447cb82c18f9e86707517add6ce5e41ef6f3c053ff75dab.sig: Pulling from home-assistant/raspberrypi5-64-homeassistant
unsupported media type application/vnd.dev.cosign.simplesigning.v1+json
