Hey yall,
Was using a Raspberry Pi for HA, but the sdcard failed, so did a fresh install on a sff x86 machine yesterday. I added all of my Zigbee devices into ZHA, and built ZHA Groups for the lights.
The oddity I’m running into is that when I toggle some of the groups, from within Lovelace or the group’s Entity page in Config, lights not within the group are toggled.
This is a bit of the log - in this case I toggled GroupHallway from Lovelace, yet quite a few other lights and groups turned on.
I do see in the logs, what I assume are, issues with the Conbee II at startup:
22-01-15 13:16:19 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/bus/usb/003/020 - None
22-01-15 13:16:21 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/bus/usb/003/021 - None
22-01-15 13:16:21 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/ttyACM0 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469028-if00
22-01-15 13:16:23 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/ttyACM0 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469028-if00
22-01-15 13:16:23 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/bus/usb/003/021 - None
22-01-15 13:16:25 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/bus/usb/003/022 - None
22-01-15 13:16:25 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/ttyACM0 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469028-if00
I feel like I must be missing something fairly boneheaded. Appreciate any thoughts on where I should go from here.
