I have a fresh installation of HA os made on VirtualBox, made according to guides on the official page, and I cannot access HA homeassistant.local:8123 (or just 192.168.1.15:8123) but I can access homeassistant.local:4357 - observer where the status of the supervisor is “Connect”.
I’m having the same problems. I can ping the guest from the host by both IPv4 (in host-only mode) and IPv6 (in bridged mode), but I cannot get a Web interface on 8123.
Yes, I set EFI mode. (Or else, it simply won’t boot at all.)
Yes, I set NAT to Bridged.
Yes, the VM responds to ping.
Yes, the VM responds to ping ON 8123.
No, there is no Web interface.
Note: I am testing using bridged mode with my Wi-Fi device (as opposed to Eth). AFAIK, this should not matter.
Same problem here. I followed each step of the Getting Started so I downloaded the .vdi hassos_ova-5.11.vdi and loaded into VirtualBox VM and created a new VM and run it until the system asks for login
I am running on Mac:
the VM config is the following:
I am anyway unable to access to any of the link below (I put the IP address associated with my router in the last case )
I ended up installing Home Assistant to a fresh Ubuntu 20.04 box. It was a cakewalk compared to trying to run it from a VM. They must have broken something. If you must use a VM, consider installing a GNU/Linux distribution independently of Home Assistant first, or possibly use an older HA release (no idea which one works and whether or not it can be updated).
