Hello everyone,
I installed Home Assistant on a fresh SD card (standard procedure for dummies like myself https://www.home-assistant.io/getting-started/).
My hardware:
Raspberry Pi 3 Model B V1.2
Razberry Z-Wave Plus 5th gen chip ZM5202
I edited /mnt/boot/config.txt to contain both lines:
dtoverlay=uart1
dtoverlay=pi3-disable-bt
In my configuration.yaml:
zwave:
usb_path: /dev/ttyAMA0
OpenZwave.log says:
2021-01-04 15:05:41.276 Always, OpenZwave Version 1.4.3469 Starting Up
2021-01-04 15:06:29.044 Info, Setting Up Provided Network Key for Secure Communications
2021-01-04 15:06:29.045 Info, mgr, Added driver for controller /dev/ttyAMA0
2021-01-04 15:06:29.045 Info, Opening controller /dev/ttyAMA0
2021-01-04 15:06:29.045 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2021-01-04 15:06:29.045 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2021-01-04 15:06:29.045 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-04 15:06:29.046 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2021-01-04 15:06:29.046 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2021-01-04 15:06:29.046 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2021-01-04 15:06:29.046 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2021-01-04 15:06:29.046 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-04 15:06:29.046 Detail, contrlr, Notification: DriverFailed
What is my mistake? What do I miss?
I would really appreciate any hints!!!
