mattlward
(Matt Ward)
February 26, 2019, 12:44am
1
I am not a coder, I did read the release notes multiple times. None of the breaking changes seem to cover what I am seeing in the notifications.
The first one seems to be triggered here:
- platform: wake_on_lan
mac_address: "e0:3f:49:xx:xx:xx"
host: 192.168.1.117
turn_off:
service: hassio.addon_stdin
addon: core_rpc_shutdown
input: Desktop
turn_on:
service: send_magic_packet
host: "192.168.1.117"
The second seems to be triggered by Dark Sky:
- platform: darksky
api_key: xxxxxx
mode: daily
forecast:
- 0
- 1
- 2
- 3
- 4
- 5
I am not sure how to adjust either as they have worked for ages and are still covered in the current documentation.
Guidance would be appreciated.
Thanks Matt
It really helps to state what component your platform configuration belongs to, since often there is more than one possibility. (I.e., is it a switch, a sensor, a binary_sensor, …???)
For the first one, though, I’m guessing it’s a Wake on LAN Switch . If so, that does not have a turn_on configuration variable, so you need to remove it.
For the second one, you seem to have mixed options from the Dark Sky Weather and Dark Sky Sensor components. I’m guessing you mean to use the latter, and that does not have a mode option, so remove it.
mattlward
(Matt Ward)
February 26, 2019, 1:19am
3
Yes, I did not think to include that the first is indeed switch platform.
I am testing the reconfig now and will look at the dark sky stuff soon. Will post back if I get stuck!
dark sky - need to use scan_interval instead of update_interval
mattlward
(Matt Ward)
February 26, 2019, 1:25am
5
So, I attempted the following change to update the switch for the following platform.
mac_address: "e0:3f:49:e7:b9:14"
host: 192.168.1.117
turn_off:
input: Desktop
Error now in the notification windows…
vjmindlab
(Vjmindlab)
February 26, 2019, 1:27am
6
This is how it should be change the info for yours.
mac_address: "00-19-D1-25-34-66"
host: 192.168.50.210
broadcast_address: 192.168.50.255
turn_off:
input: DEV-PC
mattlward
(Matt Ward)
February 26, 2019, 1:51am
7
Thanks a whole bunch, that does work… The system will shut down and power on!
I didn’t mean just remove the line with turn_on, but that whole section. Are you following the directions here: Wake on LAN Switch ?
