I have 2 DS18B20 sensors ready to go into the Fridge / Freezer, the problem is, how do I actually get them in there for a nice clean, permanent installation?
Everything seems to be pretty well sealed, can you guys share how you did this? Also, I’m sure there are already sensors built in, is it worth looking at taping into those sensors and integrating?
It’s a very useful automation when combined with an alarm - after having a freezer with 40kg of meat spoil and not noticing it for weeks, that’s something I really want to avoid happening again.
Method 2: Adapt a Aqara or similar button-battery temp sensor to run off a 18650 cell. These last for months in -20c freezer temps, whereas a button battery can last days to a few weeks. The wrap everything in a plastic bag and just pop it inside the fridge or freezer. No drilling required.
If you drill through the fridge nice and close to the door edge (ie: right on the bend of the steel) you should be safe to not hit any refrigerant line.
Otherwise I think wireless is going to be your only option other than having the cable goes past the door seal. You could use individual wires at this point so they sit flatter to the fridge steel (rather than a larger round cable).
It’s not a very good idea to “plug the drain”. You”ll get water pond inside pretty quickly. Drain is there to …well, drain the water from inside…
If you could remove back plate (i guess it’s only screwed…?) you could find where cable for light and original sensor is drawn inside.
Using sealed DS18x20 cabled sensors, I found the flexible door seal didn’t conform around the cable well enough leaving a small airgap. This was just enough for water to condense and freeze.
A 3d-printed wedge-shaped shim to smooth out the surface might fix this.
Bad ASCII-art diagram:
Damn if I could just remove the back cover of this fridge im sure I could get these sensors in there somehow, its like a science project just to get access behind this rear panel.
