Friendly Name
Ive been busy programming my M5stack basic to act as a wifi alarm fob in conjuction with alarmo.
Now ive hit a bit I cant figure out, while importing the attribute sensors_open from HA, it displays the entity id.
Id prefer to have it display the entity name, Is this possible or am I going about it the wrong way?
  friendly_name: Alarm Fob
esp32:
  board: esp32dev
  framework:
    type: arduino
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  #miso_pin: GPIO12
i2s_audio:
  i2s_lrclk_pin: GPIO25
  i2s_bclk_pin: GPIO26
media_player:
  - platform: i2s_audio
    dac_type: external
    i2s_dout_pin: 25
    mode: mono
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "???"
ota:
  password: "???"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Alarm-Fob Fallback Hotspot"
    password: "???"
captive_portal:
text_sensor:
  - platform: homeassistant
    entity_id: alarm_control_panel.alarmo
    attribute: open_sensors
image:
  - file: "caution.png"
    resize: 100x100
    type: rgb565
  - file: "greentick.png"
    resize: 100x100
    type: rgb565
  - file: "redcross.png"
    resize: 100x100
    type: rgb565
  - file: "moon.png"
    resize: 100x100
    type: rgb565
font:
  - file: "fonts/comic.ttf"
color:
  - id: my_red
    red: 100%
    green: 3%
    blue: 5%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_grey
    red: 50%
    green: 50%
    blue: 50%
  - id: my_black
    red: 0%
    green: 0 %
    blue: 0%
  - id: my_white
    red: 100%
    green: 100 %
    blue: 100%
binary_sensor:
  - platform: gpio
    pin: 39
    device_class: opening
  - platform: gpio
    pin: 38
  - platform: gpio
    pin: 37
output:
  - platform: ledc
    pin: 32
# Define a monochromatic, dimmable light for the backlight
light:
  - platform: monochromatic
    output: gpio_32_backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
display:
  - platform: ili9xxx
    model: m5stack
    cs_pin: 14
    dc_pin: 27
    reset_pin: 33
    lambda: |-
      it.fill(my_black);
      it.line(0, 238, 320, 238);
      it.line(0, 188, 320, 188);
      it.line(0, 188, 0, 238);
      it.line(110, 188, 110, 238);
      it.line(210, 188, 210, 238);
      it.line(318, 188, 318, 238);
      it.printf(50, 0, id(my_font), id(my_green), TextAlign::TOP_LEFT,  id(alarm_state).state.c_str());
      it.printf(50, 20, id(my_font), id(my_green), TextAlign::TOP_LEFT,  id(failed_sensors).state.c_str());
      if (id(wifi_signal_db).state < 5)  {
        it.printf(200, 0, id(my_font), id(my_green), "Wifi: %.1f", id(wifi_signal_percent).state);
        it.print(30, 200, id(my_font), id(my_red), TextAlign::TOP_LEFT, "Arm");
        it.print(235, 200, id(my_font), id(my_green), TextAlign::TOP_LEFT, "Disarm");
      } else {
        it.print(200, 0, id(my_font), id(my_red), "No Wifi");
        it.print(30, 200, id(my_font), id(my_grey), TextAlign::TOP_LEFT, "Arm");
        it.print(235, 200, id(my_font), id(my_grey), TextAlign::TOP_LEFT, "Disarm");
      if (id(alarm_state).state == "disarmed") {
        it.image(110, 70, id(my_tick));
      if (id(alarm_state).state == "armed_away") {
        it.image(110, 70, id(my_cross));
      if (id(alarm_state).state == "arming") {
        it.image(110, 70, id(my_caution));
      if (id(alarm_state).state == "armed_night") {
        it.image(110, 70, id(my_moon));
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    name: "WiFi Signal dB"
    update_interval: 5s
    entity_category: "diagnostic"
  - platform: copy # Reports the WiFi signal strength in %
    source_id: wifi_signal_db
    name: "WiFi Signal Percent"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "Signal %"
