Friendly Time Conversion not working
New to Home Assistant so forgive any newbie mistakes.
I have the following in my Configuration.yaml to create a custom Template Sensor for displaying my UPS Runtime as a Friendly String instead of displaying only the seconds remaining.
   sensors:
     myups_battery_runtime_friendly:
       friendly_name: 'UPS Time Remaining'
       value_template: "{{ states('sensor.myups_battery_runtime') | int | timestamp_custom('%H Hours, %M Minutes, %S Seconds', 0) }}"
sensor.myups_battery_runtime is currently showing a value of 4944. If I manually do the conversion to hours I get: 1.373333 Hours.
When using the above value_template I am getting: 01 Hours, 22 Minutes, 24 Seconds
Why the difference of ~15 Min?
sensor.myups_battery_runtime is the seconds of remaining battery runtime as returned from the NUT UPS Integration.
The β€œ.373333” of β€œ1.373333” is 37-one hundredths of an hour, not 37 minutes.
60 minutes per hour * 0.37 hours = 22.2 minutes. It’s working perfectly. :slight_smile:
Thank You. Makes 100% sense. Thought I was losing my mind.
I’ve been there. :slightly_smiling_face:
