Why is like that? Do i have to write somekind of automation, that pulls data every few minutes? Another sensors provide automatically with no problems at all.
As well as these smoke detectors have sirens, i can trigger alarm at any time and turn it off. So the link with the device is working. Except is not providing temp. data.
I suspect the reason is because it’s a battery device which spends most of its time sleeping to conserve battery.
It won’t send non-critical entity (temp, batt & voltage) updates constantly. More likely it’ll only update those when it “checks-in”.
Leave it alone for 24h without forcing any refreshes, then go back and have a look at the temperature entity history to see the frequency it was updated in the past day.
it’s not the only battery device. Much smaller device with much smaller battery is reporting temp. Of course not that often, only 5 measures over the last 12 hours, but it still does that. As i remember from the user manual the smaller sonoff sensor reports temp. only when it is changing or etc. just to prevent battery life.
Yes, i’m using grafana.
Yes, zigbee network is stable, other devices are reporting.
It was not reporting neither when temp. is changing, neither when temp. is stable.
Actually everything here is new (for me as well)
New installation of Grafana + new zigbee network (all zigbee devices are also new).
So i’m just building it from scratch. Except home assistant. I’m using it for year now.
So smoke detectors are also new.
I did not knew about that “reporting” tab, this is new for me. Hope that i will make it report, paying battery price
Yes. All three smoke sensors behaves the same. They are not reporting until manually refreshed. But now, thanks to @ShadowFist for the idea, i’ve changed one of the smoke detectors configuration in the “Reporting tab” and indeed it started to reporting. So i will do that for others, and hope it will be sorted out
You know, i only interested now in the fields available in reporting tab.
What does it mean: “Endpoint”, “Cluster”, “Attribute” and etc. Maybe there is somewhere manual for it?
Please consider marking my post above with the Solution tag. It’s the custom of the community to assign the Solution tag to the first or best post that explains the cause of the problem and provides a solution.
By setting the Solution tag it will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
