Hi HA community,
in my setup ZHA is running with the Conbee II. I managed to pair the device well and a power sensor is created. But the values are completely wrong because my electricity meter works with 10000 imp/kWh. And I can not find the value pulse configuration unfortunately.
Does anyone know how to change the pulse rate?
"manufacturer": "frient A/S",
"model": "EMIZB-141"
"active_coordinator": false,
"entities": [
"entity_id": "sensor.powermeter1_battery",
"name": "frient A/S EMIZB-141"
"entity_id": "button.powermeter1_identify",
"entity_id": "sensor.powermeter1_instantaneous_demand",
"entity_id": "sensor.powermeter1_summation_delivered",
"entity_id": "switch.powermeter1_switch",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "unknown 1 device_type of 0xc0c9 profile id"
"name": "METER_INTERFACE"
"user_given_name": "Powermeter1",
"device_reg_id": "*******************6088",
"area_id": "keller",
"cluster_details": {
"1": {
"device_type": {
"name": "unknown",
"id": 1
"profile_id": 49353,
"in_clusters": {
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"unsupported_attributes": {}
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {},
"out_clusters": {}
"2": {
"device_type": {
"name": "METER_INTERFACE",
"id": 83
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "frient A/S"
"0x0005": {
"attribute_name": "model",
"value": "EMIZB-141"
"0x0001": {
"endpoint_attribute": "power",
"attributes": {
"0x003e": {
"attribute_name": "battery_alarm_state",
"value": 0
"0x0021": {
"attribute_name": "battery_percentage_remaining",
"value": 200
"0x0033": {
"attribute_name": "battery_quantity",
"value": 2
"0x0031": {
"attribute_name": "battery_size",
"value": 3
"0x0020": {
"attribute_name": "battery_voltage",
"value": 30
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0020": {
"endpoint_attribute": "poll_control",
"attributes": {
"0x0000": {
"attribute_name": "checkin_interval",
"value": 13200
"0x0702": {
"endpoint_attribute": "smartenergy_metering",
"attributes": {
"0x0000": {
"attribute_name": "current_summ_delivered",
"value": 90956
"0x0304": {
"attribute_name": "demand_formatting",
"value": 248
"0x0302": {
"attribute_name": "divisor",
"value": 1000
"0x0400": {
"attribute_name": "instantaneous_demand",
"value": 4826
"0x0306": {
"attribute_name": "metering_device_type",
"value": 0
"0x0301": {
"attribute_name": "multiplier",
"value": 1
"0x0200": {
"attribute_name": "status",
"value": 0
"0x0303": {
"attribute_name": "summation_formatting",
"value": 248
"0x0300": {
"attribute_name": "unit_of_measure",
"value": 0
"0x0100": {
"attribute_name": "current_tier1_summ_delivered"
"0x0102": {
"attribute_name": "current_tier2_summ_delivered"
"0x0104": {
"attribute_name": "current_tier3_summ_delivered"
"0x0106": {
"attribute_name": "current_tier4_summ_delivered"
"0x0108": {
"attribute_name": "current_tier5_summ_delivered"
"0x010a": {
"attribute_name": "current_tier6_summ_delivered"
"0x0b01": {
"endpoint_attribute": "meter_id",
"attributes": {},
"0x0b05": {
"endpoint_attribute": "diagnostic",
"attributes": {},
"out_clusters": {
"0x0003": {
"attributes": {},
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4117, maximum_buffer_size=82, maximum_incoming_transfer_size=1500, server_mask=11264, maximum_outgoing_transfer_size=1500, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0xc0c9",
"device_type": "0x0001",
"input_clusters": [
"0x0005",
"0x0006"
"output_clusters": []
"2": {
"profile_id": "0x0104",
"device_type": "0x0053",
"input_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0020",
"0x0702",
"0x0b01",
"0x0b05"
"0x0003",
"0x000a",
"0x0019"
"model": "EMIZB-141",
"class": "zigpy.device.Device"
https://www.develcoproducts.com/media/5110/emizb-141-technical-manual.pdf
