What is your suggestion?
I changed the settings as follows, the error persists.
mqtt:
host: 192.168.1.101/24
user: mqttuser
password: pass
cameras:
camera_1:
ffmpeg:
inputs:
- path: rtsp://name:[email protected]/stream1
roles:
- detect
- rtmp
detect:
width: 1280
height: 720
detectors:
cpu1:
type: cpu
cpu2:
type: cpu
[2023-04-07 00:08:04] frigate.app INFO : Starting Frigate (0.11.1-2eada21)
[2023-04-07 00:08:04] frigate.app INFO : Creating directory: /media/frigate/recordings
[2023-04-07 00:08:04] frigate.app INFO : Creating directory: /media/frigate/clips
[2023-04-07 00:08:04] frigate.app INFO : Creating directory: /tmp/cache
Starting migrations
[2023-04-07 00:08:04] peewee_migrate INFO : Starting migrations
Migrate "001_create_events_table"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "001_create_events_table"
sql ('CREATE TABLE IF NOT EXISTS "event" ("id" VARCHAR(30) NOT NULL PRIMARY KEY, "label" VARCHAR(20) NOT NULL, "camera" VARCHAR(20) NOT NULL, "start_time" DATETIME NOT NULL, "end_time" DATETIME NOT NULL, "top_score" REAL NOT NULL, "false_positive" INTEGER NOT NULL, "zones" JSON NOT NULL, "thumbnail" TEXT NOT NULL)',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE TABLE IF NOT EXISTS "event" ("id" VARCHAR(30) NOT NULL PRIMARY KEY, "label" VARCHAR(20) NOT NULL, "camera" VARCHAR(20) NOT NULL, "start_time" DATETIME NOT NULL, "end_time" DATETIME NOT NULL, "top_score" REAL NOT NULL, "false_positive" INTEGER NOT NULL, "zones" JSON NOT NULL, "thumbnail" TEXT NOT NULL)',)
sql ('CREATE INDEX IF NOT EXISTS "event_label" ON "event" ("label")',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE INDEX IF NOT EXISTS "event_label" ON "event" ("label")',)
sql ('CREATE INDEX IF NOT EXISTS "event_camera" ON "event" ("camera")',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE INDEX IF NOT EXISTS "event_camera" ON "event" ("camera")',)
Done 001_create_events_table
[2023-04-07 00:08:04] peewee_migrate INFO : Done 001_create_events_table
Migrate "002_add_clip_snapshot"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "002_add_clip_snapshot"
add_column ('event', 'has_clip', <BooleanField: Event.has_clip>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'has_clip', <BooleanField: Event.has_clip>)
add_column ('event', 'has_snapshot', <BooleanField: Event.has_snapshot>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'has_snapshot', <BooleanField: Event.has_snapshot>)
Done 002_add_clip_snapshot
[2023-04-07 00:08:04] peewee_migrate INFO : Done 002_add_clip_snapshot
Migrate "003_create_recordings_table"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "003_create_recordings_table"
sql ('CREATE TABLE IF NOT EXISTS "recordings" ("id" VARCHAR(30) NOT NULL PRIMARY KEY, "camera" VARCHAR(20) NOT NULL, "path" VARCHAR(255) NOT NULL, "start_time" DATETIME NOT NULL, "end_time" DATETIME NOT NULL, "duration" REAL NOT NULL)',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE TABLE IF NOT EXISTS "recordings" ("id" VARCHAR(30) NOT NULL PRIMARY KEY, "camera" VARCHAR(20) NOT NULL, "path" VARCHAR(255) NOT NULL, "start_time" DATETIME NOT NULL, "end_time" DATETIME NOT NULL, "duration" REAL NOT NULL)',)
sql ('CREATE INDEX IF NOT EXISTS "recordings_camera" ON "recordings" ("camera")',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE INDEX IF NOT EXISTS "recordings_camera" ON "recordings" ("camera")',)
sql ('CREATE UNIQUE INDEX IF NOT EXISTS "recordings_path" ON "recordings" ("path")',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE UNIQUE INDEX IF NOT EXISTS "recordings_path" ON "recordings" ("path")',)
sql ('CREATE INDEX IF NOT EXISTS "recordings_start_time_end_time" ON "recordings" (start_time, end_time)',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE INDEX IF NOT EXISTS "recordings_start_time_end_time" ON "recordings" (start_time, end_time)',)
Done 003_create_recordings_table
[2023-04-07 00:08:04] peewee_migrate INFO : Done 003_create_recordings_table
Migrate "004_add_bbox_region_area"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "004_add_bbox_region_area"
add_column ('event', 'region', <JSONField: Event.region>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'region', <JSONField: Event.region>)
add_column ('event', 'box', <JSONField: Event.box>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'box', <JSONField: Event.box>)
add_column ('event', 'area', <IntegerField: Event.area>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'area', <IntegerField: Event.area>)
Done 004_add_bbox_region_area
[2023-04-07 00:08:04] peewee_migrate INFO : Done 004_add_bbox_region_area
Migrate "005_make_end_time_nullable"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "005_make_end_time_nullable"
drop_not_null ('event', 'end_time')
[2023-04-07 00:08:04] peewee_migrate INFO : drop_not_null ('event', 'end_time')
Done 005_make_end_time_nullable
[2023-04-07 00:08:04] peewee_migrate INFO : Done 005_make_end_time_nullable
Migrate "006_add_motion_active_objects"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "006_add_motion_active_objects"
add_column ('recordings', 'objects', <IntegerField: Recordings.objects>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('recordings', 'objects', <IntegerField: Recordings.objects>)
add_column ('recordings', 'motion', <IntegerField: Recordings.motion>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('recordings', 'motion', <IntegerField: Recordings.motion>)
Done 006_add_motion_active_objects
[2023-04-07 00:08:04] peewee_migrate INFO : Done 006_add_motion_active_objects
Migrate "007_add_retain_indefinitely"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "007_add_retain_indefinitely"
add_column ('event', 'retain_indefinitely', <BooleanField: Event.retain_indefinitely>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'retain_indefinitely', <BooleanField: Event.retain_indefinitely>)
Done 007_add_retain_indefinitely
[2023-04-07 00:08:04] peewee_migrate INFO : Done 007_add_retain_indefinitely
Migrate "008_add_sub_label"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "008_add_sub_label"
add_column ('event', 'sub_label', <CharField: Event.sub_label>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'sub_label', <CharField: Event.sub_label>)
Done 008_add_sub_label
[2023-04-07 00:08:04] peewee_migrate INFO : Done 008_add_sub_label
Migrate "009_add_object_filter_ratio"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "009_add_object_filter_ratio"
add_column ('event', 'ratio', <FloatField: Event.ratio>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'ratio', <FloatField: Event.ratio>)
Done 009_add_object_filter_ratio
[2023-04-07 00:08:04] peewee_migrate INFO : Done 009_add_object_filter_ratio
Migrate "010_add_plus_image_id"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "010_add_plus_image_id"
add_column ('event', 'plus_id', <CharField: Event.plus_id>)
[2023-04-07 00:08:04] peewee_migrate INFO : add_column ('event', 'plus_id', <CharField: Event.plus_id>)
Done 010_add_plus_image_id
[2023-04-07 00:08:04] peewee_migrate INFO : Done 010_add_plus_image_id
Migrate "011_update_indexes"
[2023-04-07 00:08:04] peewee_migrate INFO : Migrate "011_update_indexes"
sql ('CREATE INDEX "event_start_time_end_time" ON "event" ("start_time" DESC, "end_time" DESC)',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE INDEX "event_start_time_end_time" ON "event" ("start_time" DESC, "end_time" DESC)',)
sql ('DROP INDEX recordings_start_time_end_time',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('DROP INDEX recordings_start_time_end_time',)
sql ('CREATE INDEX "recordings_end_time_start_time" ON "recordings" ("end_time" DESC, "start_time" DESC)',)
[2023-04-07 00:08:04] peewee_migrate INFO : sql ('CREATE INDEX "recordings_end_time_start_time" ON "recordings" ("end_time" DESC, "start_time" DESC)',)
Done 011_update_indexes
[2023-04-07 00:08:04] peewee_migrate INFO : Done 011_update_indexes
[Errno -2] Name or service not known
[cmd] python3 exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
