miomia
(Miomia)
April 27, 2024, 4:06pm
1
I have cameras that write in the Frigat program. I disable LED recording and detection and motion via MQTT on the camera. But the camera still records. The information in MQTT shows that there is no recording, but recording is in progress.
alias: frigate_led_off
description: ""
- platform: state
entity_id:
- input_boolean.manual_vent
to: "off"
condition: []
- service: mqtt.publish
topic: frigate/LED/recordings/set
payload: "off"
topic: frigate/LED/motion/set
payload: "off"
topic: frigate/LED/detect/set
payload: "off"
mode: single
nickrout
(Nick Rout)
April 27, 2024, 10:40pm
2
Is there a reason you arenβt using the ha entity, probably named switch.led_recording ?
miomia
(Miomia)
April 28, 2024, 8:55am
3
I tried through full-time integration. Everything is off but the camera is writing on motion and detection.
miomia
(Miomia)
April 28, 2024, 9:00am
4
My frigate code:
LED:
ffmpeg:
output_args:
record: preset-record-generic-audio-aac
inputs:
# sub strim
- path: rtsp://admin:[email protected] :554/cam/realmonitor?channel=1&subtype=1
roles:
- detect
# main srim
- path: rtsp://admin:[email protected] :554/cam/realmonitor?channel=1&subtype=0
roles:
- record
detect:
width: 640
height: 480
fps: 5
record:
enabled: true
retain:
days: 0
mode: all
events:
retain:
default: 1
mode: active_objects
objects:
cat: 1
persone: 1
snapshots:
enabled: true
nickrout
(Nick Rout)
April 28, 2024, 10:07am
5
Perhaps use the frigate help channels. This isnβt the frigate forum.
