I have a 2nd generation nest doorbell and I integrated it into haos, but I want to use frigate to record 24/7, but as a result of some research, I saw the result of using go2rtc, I transferred the image to go2rtc but I could not transfer it to frigate.
In fact, I could not even make the frigate’s yaml file properly, so I am waiting for your help, in fact, if you have sample yaml files, can you share them so that I can change the code myself and use it (the yaml I am currently using in go2rtc
streams:
Doorbell: hass://supervisor?entity_id=camera.on_bahce)
