I just succeed to install Frigate. And I’m still in configuration mode (for objects detection, notification, …).
But I use an outdoor camera on battery with solar panel.
So I wish to save battery consumption. Is it possible to change some options to decrease battery consumption ?
Here my frigate configuration :
## Connection à MQTT ##
mqtt:
enabled: False
#cameras:
# dummy_camera: # <--- this will be changed to your actual camera later
# enabled: False
# ffmpeg:
# inputs:
# - path: rtsp://127.0.0.1:554/rtsp
# roles:
# - detect
# /config/frigate.yaml
## Choix des caméras ##
go2rtc:
streams:
my_camera:
- echo:bash /config/custom_components/expose_camera_stream_source/get_stream.sh camera.r4252_smart_outdoor_camera
## Liste des caméras avec leurs adresses de connection ##
cameras:
my_camera:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/my_camera?video
input_args: preset-rtsp-restream-low-latency
roles:
- detect
# motion: ## Création des zones à ignorer ##
# mask:
# - 0,461,3,0,1919,0,1919,843,1699,492,1344,458,1346,336,973,317,869,375,866,432
## Choix des options de détection et d'enregistrement ##
record:
enabled: True
retain:
days: 7
mode: motion
events:
retain:
default: 30
# mode: motion ## Conserve les vidéos avec mouvements seulement ##
mode: active_objects ## Conserve les vidéos avec détection d'objets ##
objects:
dog: 2 ## Durée de conservation par objets ##
cat : 2
person: 7
detect:
stationary:
# Optional: Frequency for confirming stationary objects (default: same as threshold)
# When set to 1, object detection will run to confirm the object still exists on every frame.
# If set to 10, object detection will run to confirm the object still exists on every 10th frame.
interval: 50
# Optional: Number of frames without a position change for an object to be considered stationary (default: 10x the frame rate or 10s)
threshold: 50
# Optional: Define a maximum number of frames for tracking a stationary object (default: not set, track forever)
# This can help with false positives for objects that should only be stationary for a limited amount of time.
# It can also be used to disable stationary object tracking. For example, you may want to set a value for person, but leave
# car at the default.
# WARNING: Setting these values overrides default behavior and disables stationary object tracking.
# There are very few situations where you would want it disabled. It is NOT recommended to
# copy these values from the example config into your config unless you know they are needed.
snapshots:
enabled: True
