Frigate: bounding boxes go crazy
I have a strange frigate issue - once again…
I have multiple cameras setup, same brand, same type, same HW / SW revision.
One camera surveiling carport and entrance is working like expected, showing bounding boxes in debug mode only when something is moving.
The other camera is facing the garden and shows bounding boxes like crazy - multiple boxes per second, all the time. I uploaded a short screen-cast where you can see the issue:
Both cameras run on exact same config with same filters (treshold + minscore) for different objects.
What am I doing wrong?
Cheers
it is seeing motion, without your config all that can be suggested is reducing motion detection sensitivity
Thank you, so far I only changed the threshold / min_score for objects and didn´t touch the motion sensitivity.
With following setting it behaves as expected - cheers!
motion:
      threshold: 50
