Frigate Camera Errors
So I’ve noticed in my Frigate logs that I have the following errors every 10 seconds on one of my cameras. Any thoughts on what the cause could be?
2024-04-02 16:10:37.580496016  [2024-04-02 16:10:37] watchdog.computer_camera       INFO    : Terminating the existing ffmpeg process...
2024-04-02 16:10:37.580532642  [2024-04-02 16:10:37] watchdog.computer_camera       INFO    : Waiting for ffmpeg to exit gracefully...
2024-04-02 16:10:47.588653107  [2024-04-02 16:10:47] watchdog.computer_camera       ERROR   : No new recording segments were created for computer_camera in the last 120s. restarting the ffmpeg record process...
Camera is disconnecting. Either power or signal issue
OR
Problem with video stream. Look elsewhere in log for signs of trouble.
What type of camera is this? Model?
Post config
Brand: Amcrest
Model: IP8M-2496EW-V2
mqtt:
  enabled: True
  host: 192.168.0.5
  port: 1883
  user: user
  password: pass
go2rtc:
  streams:
    computer_camera:
      - rtsp://user:pass:554/cam/realmonitor?channel=1&subtype=0
      - "ffmpeg:rtsp_cam#audio=opus"
    computer_camera_sub:
      - "ffmpeg:rtsp_cam_sub#audio=opus"
    front_door_camera:
    front_door_camera_sub:
cameras:
  computer_camera:
    ffmpeg:
      output_args:
        record: preset-record-generic-audio-aac
      hwaccel_args: preset-intel-qsv-h264
      inputs:
        - path: rtsp://127.0.0.1:8554/computer_camera
          input_args: preset-rtsp-restream
          roles:
             - record
        - path: rtsp://127.0.0.1:8554/computer_camera_sub
          input_args: preset_rtsp_restream
          roles:
             - record
    objects:
      track:
        - person
        - cat
      filters:
        person:
          min_score: 0.7 # min score for object to initiate tracking (default: 0.5
          threshold: 0.8 # min decimal percentage for tracked object's computed score to be considered a true positive (default: 0.7)
    detect:
      enabled: True
      width: 640
      height: 480
    snapshots:
      enabled: True
      retain:
        default: 3
      timestamp: True
      bounding_box: True
      crop: True
      height: 500
    record:
      enabled: True
      retain:
        days: 2
        mode: active_objects
  front_door_camera:
    ffmpeg:
      output_args:
      inputs:
        - path: rtsp://127.0.0.1:8554/front_door_camera
          roles:
             - detect
        - path: rtsp://127.0.0.1:8554/front_door_camera_sub
          roles:
             - record
    objects:
      track:
        - person
        - cat
      filters:
        person:
          min_score: 0.7 # min score for object to initiate tracking (default: 0.5)
    detect:
      enabled: True
      width: 640
      height: 480
    snapshots:
      enabled: True
      retain:
        default: 3
      timestamp: True
      bounding_box: True
      crop: True
      height: 500
    record:
      enabled: True
      retain:
        days: 2
detectors:
    cpu1:
      type: cpu
front_door_camera:
  - rtsp://rtsp://user:pass:554/cam/realmonitor?channel=1&subtype=0
Should be
front_door_camera:
You got rtsp twice in url
Not sure if that was camera giving issues
Sorry, that’s a copy/paste error. And yea, that’s not the camera giving me issues
