Edit: this problem seems to be related to the use of SMB share for clips. Using a local drive solves this issue.
I have a camera with the following RTSP stream and substream URL. I can use this URL in VLC to view the camera:
rtsp://user:[email protected]:554/live
rtsp:///user:[email protected]:554/cam/realmonitor?channel=1&subtype=1
But when I put it into the camera config of the yml file, I’m not getting any camera feed.
My frigate.yml looks like this. I’ve tried both the main stream and the substream, but I’m unable to get any camera to work.
cameras:
# Name of your camera
driveway:
ffmpeg:
inputs:
- path: rtsp://user:[email protected]:554/live
roles:
- detect
- rtmp
width: 2688
height: 1520
fps: 5
Wondering if someone can share their config? I’m confused why the example config has the word “viewer” stuck int he RTSP stream, so I’ve also tried this:
- path: rtsp://viewer:user:[email protected]:554/live
Nothing in logs jump out at me:
* Starting nginx nginx
...done.
frigate.app INFO : Creating tmpfs of size 256m
Starting migrations
peewee_migrate INFO : Starting migrations
database is locked
...done.
Starting migrations
database is locked
...done.
Starting migrations
database is locked
...done.
Starting migrations
database is locked
...done.
Starting migrations
