So I seem to have bad luck. Most of the time that I want to show off my HA install to friends or even potential clients I end up running into bugs.
This time it has to do with Frigate integration. It used to work great, but I don’t view clips often via HA. I think last time I checked it out was little over a month ago.
It seems the Frigate integration with HA is not able to play clips.
If you click/hover on the right side of the live video feed you get a list of clips available for that camera. As you can see it even shows how long the clip is
However, when I try to view a clip it shows this:
I then went to my Media Folder, looked in the Frigate clips and it does show the clips there, but again if I try to view them they don’t play.
I contacted the Frigate team via the github page and they mentioned it is a HA bug.
I tried to restore to Nov 17th (the oldest backup I have) but the issue is still there.
Any ideas of how I could fix the issue? And if there is no “fix” for it at the moment, how can I report the bug to HA?
